Tomax 0
I need some help with json decoding.
I'm succesfully got the data in HC2 from Rasspery/Pyton but I'm not able to decode that data in HC2.
Any advice, please?!
--starting LUA code here
local smartmeter= Net.FHttp('192.168.1.10');
response = smartmeter:GET("/index.py")
fibaro:debug('Answer: ' ..response) --this is the data response coming from Rasppery/Pyton: {"Amp": 13.29, "Volt": 98.01}
if (tonumber(status)==200 and tonumber(errorCode)==0) and response~=nil
then
fibaro:debug('Decoding...')
local harduino = json.decode(response)
fibaro:debug('Decode: ', harduino)
fibaro:debug('Or decode: ', harduino.Volt)
else fibaro:debug('Not able to decode!') -- this is the executed code
--end LUA code here
