Fibarobot for Telegram
Zodchij
Telegram messenger became more popular and it is cool to use it for Home Center notification also.
You can use FibaroBot to convert emails from HC to regular Telegram messages.
This solution can be easy used both on HC2 and HCL and does not required scripting.
/monthly_2018_01/_text_EN.png.4f9bdce93093ce8e6f4ee3dbfeffee5d.png" />
Messages not limits only to text, but can be used for camera snapshots delivering.
You can read more details about the bot
Bot link in telegram is
P.S. Please share your feedback or ideas of using the bot.
Edited by Zodchij
Updated Description
  • 1 month later...
  • @Landshark if you are asking about adding timestamp to the message just use simple code:
    Does it help?
    • 2 months later...
    Hi @Zodchij
    Since we're closing this part of the Forum, I'd like to ask you to move this topic to Home Automation.
    It'd be much appreciated! ;)
    • 2 years later...
    • 1 year later...
    Does think work anymore? Went to the telegram bit, can't be able to even get the I'd for a start.
    • 4 weeks later...
    this is not working anymore, is there another way to have telegram used for notificATIONS?
    Yes it is possible, please check here:
    My UHAS for HC2 supports Telegram, Pushover, GroupMe, WhatsApp and Singal. For more details please check here:
    Will make UHAS for HC2 available before end of September this year.
