Touch Switch working on Wifi
Ananta Creation
7 answers to this question
Hi @Ananta Creation!
Our Z-Wave controller, Home Center, supports Z-Wave modules and some other devices via plugins and integrations.
Basically, there should be no problem with integrating Z-Wave switches made by other companies.
However, those two switches cannot be integrated with our controller.
Since it's a Z-Wave switch it should be compatible but I cannot give you any guarantees.
Hi @Soft,
Since it is traditional relay switch behind that glass and 2 buttons, i think that On/Off should work. But no one can garantee other functions.
Also, i have experience with those (T41x series):
There i can garantee, that basics are working. I tested some of those.
Best regards,
Jakub
    Hi, I am located in India and using Z-wave Indian frequency controller. In India there are limited products working on Z-wave Indian frequency. So If there is any possibilities to integrate with other Touch switch which are working on Wi-Fi or RF via their Gateway, then it would be great help.
