Linked devices
jack.daniels
I have a humidity device connected by the fibaro wall plug and a sensor.
I have linked it inside the linked devices panel but it seems there is no effect. The wall plug does not change its state nevermind how big/low the sensor value.
I tried the week schedule, manual and holiday mode as well.
Any info regarding how the linked devices works available?
May be there is some solution for such cases? Just a manual target value selection with a slider is enough
Ty
  • 19 minutes ago, I.Srodka said:
    What thresholds did you set?
    When should the Wall Plug act?
    If you mean the sensor mesurements report thresholds - its default value for AEON Multisensor 6.
    The wall plug should be ON when current mesurements < target
    What screenshots you need to see? Humidity panel?
    Which part of the system tells you it is set up this way?
    I expect You to tell me :)
    The Fibaro manual says: Link devices and shedule in Humidity panel.
    Okay, so in that case you should start by reading this article:
    This is the one I mention before. It says just link 2 devices. No more settings available. Tell me what to do next, please
    Okay, but then you need to set up the zone and a schedule:
  • Solved, thanks
    The problem was: zones were created, but no room assigned for each zone. Need to add this step to the manual.
