Guest Bastian
i had installed a few days ago my first dimmer 2. It works fine with my in wall LEDs.
But one question; If i turn off the light with the dimmer the LED lamps "fade out". I search an option to disable the fade out effect and ant to have a "switch off, lamps get off immideately.
Is there an option/parameter to turn off this fade out effect?
Thanks and best regards
1 answer to this question
