LaMetric Time
10der
 Hi!
Tomorrow I finally bought Ukrainian startup device named "LaMetric Time" :)
today I want to share simple VD for LaMetric Time
* Can turn ON / OFF radio
* Switch radio stations
* Set device Volume
* Switch applications on face
* Send simple notifications to device from HC2 (via global value)
configure:
1) set ip address
2) set two global values
 * LaMetricDev  you API key
 * LaMetricMessage
set icons to all buttons
for send a notification to device - simple set LaMetricMessage
bonus: how to write simple LaMetric Application.
Show climate in your home in each room what you can define in code:
18 answers to this question
On 6/14/2017 at 9:43 AM, petergebruers said:
I mean "delete" (unfortunately, ... because you'll have to change the ID in your code) and "clicking the button".
On 1/20/2018 at 1:01 PM, 10der said:
 Hi!
* Set device Volume
configure:
1) set ip address
 * LaMetricMessage
I got a LaMetric too. Very neat to display shorter information messages.
I use it as my "kitchen clock". I push environmental measurements to it every 2 minutes and notifications when laundry is done etc.
" to "
Temat został przeniesiony z "
" do "
Hi @10der,
did you succeed to retrieve the list of apps from API?
the doc's say that:
Returns the list of installed apps
but afaik it does nothing...
  • just a moment, friend
    Edited by 10der
    Piece of my code:
    and debug gives me:
    /monthly_2019_09/image.png.5eeece4cfcda2694bcaa891fea32b0a3.png" />
    I must be crazy.....
    Edited by Bodyart
  • crazy!
    VD is empty!
  • I have copy past json code from response yo own ww server
    the result is same.
    next steps - I have cutting json from bottom, also step by step.
    and at some moment
    /monthly_2019_09/image.png.d61532f83a2b8976abbf8755569157a4.png" />
    IDK! :( size?
  • ye, I am blighter, stickler for detail man.
    it's not response length. it's count json nodes, IMHO
  • 2 hours ago, HomeSystem.sk said:
    Hey guys, did you get the notification working on this?
    notification ?
    ahh stop. are you asking about - is fibaro working on this issue? i do not know. usually fibaro do not care about any issues here.
    Edited by 10der
    Hi, i mean if it is possible to show notifications from fibaro to lametric. I can not get it to work now for some reason.
    call
    where 122 is Id of scene above
    Edited by 10der
  • UPD: Slovakia
    Edited by 10der
