ggoetz56 9
is there a possibility to read the routing table. What I know is that I.e. HC2 tries 3 routes to send a command to a remote node through the mesh net, then stops communication with the desired node. The maximum count of possible hops are 5 (4 routing devices).
This is what I found in the advanced User Guide:
The user can access the routing table. There are several software solutions, typically called installer tools, which visualise the routing table to optimize the network setup.
But I don't find any Scripts, installer tools, LUA-Code, etc. concerning about that topic.
Any hints to start for me?
Gerhard
4 answers to this question
