Grouping Disappearing
fuuss
I don't know if this is working as designed or a bug
I wanted to group a button to a dimmer .
I went into the advanced configuration and added the dimmer to the Switch in the  Device grouping.
After saving the dimmer disappear , at this point i just can switch the lamp on or off dimming is not possible anymore as I can only push the button
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
Hi @fuuss!
The grouping was not meant for this.
On 5.02.2018 at 8:56 PM, Jamie mccrostie said:
If you want control of both seprately  use association.
Yes, that's what associations are for.
  • Thanks for clarification :-)
    Edited by fuuss
