sergiobaiao 5
Hi there,
I`m a integrator for home automation products in Brazil. I mainly sell Lutron and Fibaro products. I use both systems in my showroom, and i already control the Lutron system from Fibaro by using LUA scripts.
Now i want to control Fibaro from Lutron. I know that i can connect to HC2 using port 11111 and send a http GET/POST command. The problem is that Lutron HWQS system only sends ASCII commands to third party devices. I`m trying to send this command from Lutron:
GET /api/callAction?deviceID=153&name=turnOff HTTP/1.1
Host: 192.168.0.247
Authorization: Basic YXBpOmFwaQ==
but i need it to be a one line command, to be sent as in a telnet connection. I tried the following:
GET /api/callAction?deviceID=153&name=turnOff HTTP/1.10x0D0x0AHost: 192.168.0.2470x0D0x0AAuthorization: Basic YXBpOmFwaQ== 0x0D0x0A0x0D0x0A
that didn`t work also, returns an HTTP/1.1 400 Bad Request
if i connect over telnet to port 11111 and type line by line the following command it works:
Host: 192.168.0.247
is it possible to "encode" this so i can send it as a one line command so i can control my fibaro system from my lutron system?
4 answers to this question
