Turn on and off QNAP from a FIBARO
Stefan87
I would like to control the QNAP disk storage via HC2.
QNAP I use to play movies on TV, so it does not make sense to run when no one is at home. I could turn it off with a socket, but it would not prove to be a HDD.
In a FIBARO is a module "WakeOnLan".
Did you set it up in collaboration with QNAP? Turning on after coming home and turning off after leaving?
Thanks!
so, you can write VD, connect to QNAP via telnet and tun poweroff command.
  • Thank you very much!
