Plug-ins
Gondo
I'm just deciding which gateway I should buy - HC 2 or HC Lite. I don't need voice control, VOIP, master controller or LUA. I plan connect 5 thermostats, 7 blind controllers, some door and window sensors, 2 water leak sensors, sliding gate, 3 RGBW controllers and maybe some power outlets.
The only difference between HC 2 or HC Lite I've found are plug-ins. But I didn't find any info about them. Are they important? What are plug-ins for?
The price of HC 2 is more than double than HC lite. Are the plug-ins worth for this price?
6 answers to this question
LUA, LUA,LUA.
  • OK, many thanks everyone for the answers.
    So my first question about plug-ins is unnecessary, I understand that HC2 is far better and I have decided to buy it.
    Hi
    With the number of devices you have planned, you should purchase an HC2.
    It has much more power, and most importantly (like Jamie McCrostie @ writes) it can run lua.
    HCL can also run plug ins.
    My HCL is a bit overloaded, you can see configuration at the bottom.
  • 32 minutes ago, hTiger1 said:
    Hi
    Thanks for your reply.
    I'm not coder, so I'm not interested in programming in LUA. I choose Fibaro because of easy "block" programming.
    And about number of connected devices - Fibaro website claims that it's possible to connect 230 devices to HCL. I read somewhere that it is better to connect 150 devices max., but this number is still far over my plans. I'll have maybe 35-40 devices in the future.
    Is HCL really so weak? I think that HC2 is for me like "hunt sparrows with a cannon" as we say in Czech language. :)
    I also recommend a HC2 instead of a HCL. The coding is something you'll get on the way ;)
    The HC2 is much more powerful than a HCL.
    @Gondo Its not about you writing
    lua code, its about you using and adapting other peoples code.
    This is a huge advantage.
    Most is just copy and paste and filling out id numbers.
    Block scenes are a good way to get started but have many limitations.
