winromulus 19
Adding an Eurotronic Spirit Z-Wave Plus device to a HC2 results in errors regarding a missing template. (I'm still fairly new to Fibaro HC2 and I'm not sure what this means).
I've also attached the device template from that screen to this question.
Does Fibaro have an ETA on this?
I've look through the template XML and it seems some of the values are wrong: The device should support Thermostat Modes: 0,1,11,15,31 while in the template it seems that only 0,1,11,15 are supported. The "31" mode is manufacturer specific mode, which is very important since it allows the device to be operated as a simple valve (at least that's what I understand from the manual).
I'm mentioning @T.Konopka since I found multiple posts regarding Eurotronic on the Polish forum but I don't understand if work is in progress for this device.
Thanks,
17 answers to this question
