Guest DigitalT
I have two smoke sensors connected to a SC2, the smoke sensors used to report smoke density but stopped doing this at some point, not sure when or why.
A self test using the center button says they are ok and temperature is reporting as normal to the HC2.
I have tested both sensors exposing them for smoke, no report to back to HC2 of any smoke. Both devices are also set to "High sensitivy"
How can I get density reporting to work?
14 answers to this question
