Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
Gianluca S.
FGT-001 - New Firmware Available: 4.0 > 4.3
Hi Guys,
The new firmare is aivaliable for our FGT-001 heating valves.
The version is 4.3. Im updating my 6 valves. Each valved take more than 20 minutes to complete the procedure.
Cross the finger and share the experience....
 If you are running HC FW older than 1.462 (beta) do not perform remove/reset/include after update TRV's FW.
(Thanks to adyboss for the suggestion)
Edited by Gianluca S.
Share this post
Link to post
I quite agree with you Jon798.
Much of this mess would have been found quickly with these measures.
All I can see is that someone thinks the costumers are too stupid to learn anything from these readings.
Edited by svaleb
Share this post
Link to post
I have swapped a couple of emails with Fibaro Tech support who said there should be a new firmware update in 2-3 weeks. No more information than that available to me...
Cheers,
Jon.
Share this post
Link to post
Last week I installed the controllers in the bathroom. And there I've got all the problems the rest have got. Now I installed three more controllers in the living room and these look like they are working fine. And this with the external temp sensor. I think Petergebruers said he also had some rooms working and some not.
Could it have somehting to do with the type of radiotor and connection of the valve? My bathroom and living room both have different radiators.
Share this post
Link to post
Yes. If you send the "blackbox logs" then Fibaro can analyze them. They can detect issues like, for example, a valve set to 0% but actually not being closed fully. They are also interested in logs of *working* setups, to verify the operation of their algorithms.
Share this post
Link to post
On 20-3-2018 at 12:43 PM, petergebruers said:
The BLE sensor reports every 10 minutes, the FGT reports when there is a +/- 0.5 difference between the BLE report and the last FGT report. Probably 4.3 adds some reporting after several hours, the older version did not do that so if you had a constant room temperature, you might not have any FGT report for several hours. If the FGT does not report, it means room temp measured by the sensor deviates by less than +/- 0.5°C.
Do I understand that the algorithms take in account the temperature from BLT and valve itself? That is never going to work in my case where the valves are behind the cover in front of the radiator. It will always be much warmer there than with the BLT.
Or is it just reporting that is done with tempearture differences between both?
Share this post
Link to post
Hi all,
Any reason why this 4.3 firmware upgrade does not show up for me?
KR,
Kristof
Share this post
Link to post
Hi @kristofre ,
Please, check slave number one for update. There you should see it. Sorry it is in CZ. But layout should give you an idea where to look in device settings.
/monthly_2018_03/Fib_hlavice_slave.jpg.0ce2324c740e86e3ae7942bf08daf2f1.jpg" alt="Fib_hlavice_slave.jpg.0ce2324c740e86e3ae7942bf08daf2f1.jpg" />
Share this post
Link to post
1 minute ago, jakub.jezek said:
Hi @kristofre ,
Thanks Jakub!
Any reason why it is not on the main device? Also, why did I not get a notification for it?
Share this post
Link to post
5 minutes ago, kristofre said:
Thanks Jakub!
No clue. I did find about 1st slave, when i wanted to upgrade some Dimmers.
Share this post
Link to post
On 3/13/2018 at 9:40 AM, Bezan said:
Hi, after update I still have non working valve too...
Temperature from plan is 21,5, in room 22,5 and valve is open. In HC it is showing OFF for one and 21,5 fo second in this room. Module is living its own life.
In bathroom valve after turning on is turning MAX / OFF since 1 hour in a loop.
I was able to add additional temperature sensor once. After some location changes and valve reset it is not accepting temperature sensor again.
I feel like we are working to get Fibaro module working but still paying full price for non working device. I`m very close for asking for refund.
I had it too, yesterday i did new calibration of all trv's. now it looks ok again.
Can you try a new calibration? (menu-white-confirm)
Share this post
Link to post
Is there any news on a new firmware update?  Here in the UK we have finally had a little nice weather, which is great but highlights that we might be running out of time to test a thermostatic radiator valve...
Thanks,
Jon.
Share this post
Link to post
Valid question. I can see you are fairly new around here ;-)
Fibaro rarely discusses release dates of... well.. just about anything :-D
So all I know is: "they are working on it". Personally, if I was still on 4.0, I'd skip 4.3.
Sometimes though they surprise me.
I'm in Flanders and I bet we cannot test TRVs this week. Actually, I really hope we cannot test, because we have barely seen the sun since September.
Share this post
Link to post
So... no news yet? :)
The summer is almost everywhere...
Share this post
Link to post
Hi Peter,
Can these blackbox logs be send to support@? or do they have to be send to another mail address?
I have some logs:
Heatpanel: everytime of day 10 degrees
But I hear the valve change position regularly while room is above 20 degrees continuous.
Main heating closed because my radiator will warm the room even more.
Share this post
Link to post
Yes. Please do so.
I am not sure what you mean by "regularly". Once per week is normal (automatic descale, calibration). If it is more often, ...
Anyway, Fibaro is still preparing new firmware (to replace 4.3) based on user reports, like yours. No ETA.
Share this post
Link to post
On 29-4-2018 at 10:29 AM, petergebruers said:
Yes. Please do so.
It is multiple times per hour. Just send in the blackbox logs. Hope these can help them.
Share this post
Link to post
I send in blackbox logs. Conclusion of Fibaro is unit is defective because it is constant open.  I can hear it move often but it seems not to close. Today I checked my HC2 and got "motor failure" from my other valve. Not very hopefull for the future. Awaiting new firmware before sending both in for RMA.
Share this post
Link to post
Fibaro said in March that "in next 3 weeks a new FW will be available"... ;(
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
