[Solved] UradMonitor - Anyone that can help with importing values into HC2?
Teza
I have bought an UradMonitor A3. (www.uradmonitor.com)
This is a sensor system that provides readings of:
Temperature
Pressure
Humidity
VOC
PM2.5
Formaldehyde
Carbon Dioxide
γ,x-rays
I know some have connected it to Homeseer, but have anyone connected it to the Fibaro system?
It can provide readings over wifi and via the internet.
Anyone that know how this unit can be implemented into the Fibaro system?
Would like the current values from the UradMonitor in HC2, so it can be used in scenes.
I think this is the homeseer code:
Edited by Teza
Solved
  • Can this be transfered / written in LUA code somehow?
    An exapmle to get the values in HTML.
    Some html code to get the readings:
    Javascript code to the html:
    Will give a result like this:
    /monthly_2018_03/Skjermbilde.PNG.8beede9f8aac2e806547cbf3fc3bbac8.PNG" />
    Edited by Teza
  • I have found that I can type in an ip adress in my web browser and receive the following information:
    /monthly_2018_03/Skjermbilde1.PNG.fd182ddd5154b4905ce285c7a3efcf88.PNG" alt="Skjermbilde1.PNG.fd182ddd5154b4905ce285c7a3efcf88.PNG" />
    When I look on the html code for that page, it looks like:
    If I create a viritual device in HC2 and use the IP adress for the UradMonitor, is it possible to get these values into the Fibaro software with LUA code?
  • By using 192.168.8.106/j, I get a json link:
    {"data":{ "id":"8200007A","type":"8","detector":"SI29BG","voltage":382,"cpm":14,"temperature":9.45,"humidity":48.29,"pressure":100281,"voc":12800000,"co2":399,"noise":39,"ch2o":0.00,"pm25":3,"uptime": 107787}}
    How can I convert this to values with lua code?
    • 1 month later...
    • 5 months later...
  • Solved.
