Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
is there a way to make home or away Variables by using your wifi at home so the Fibaro system nows when I ip dress comes into the area it know someone is home
Share this post
Link to post
UPD:
create toggle button instead of two buttons home/away
Share this post
Link to post
do you ask how set alarm if nobody at home?
based  on VD from previous  message
scene 150 simple set home alarm
for example!
Edited by 10der
Share this post
Link to post
@10der
Clever to use the autopresence counter in other scene too!
Till now, my solution was to check all global variables of family members, if all are gone set alarm.
Share this post
Link to post
Hi people
I ve been trying this, ut I face some issues. Let me know if anyone else, had the same situation.
When my mobile phone is too long without use, it doen´t work. I am at home, in my wireless network, but fibaro can not find me.
I tried prior the test, 30 or 40 seconds before send a push notification (identifing user position) to wake my mobile, however it doesn´t seen to work.
In my case, the best solution (not the ideal) if use two tests, fist using IFTTT (that sometimes also fail) and than testing my presense in wireless network). It works, but in many cases present the wrong result...
Is the a precise way, I mean, that work a 100% to identify my presence?
Regards
Share this post
Link to post
Share this post
Link to post
4 hours ago, 10der said:
Don’t iBeacons require an app installed on phone to monitor its distance from these beacons or tags? Don’t they use Bluetooth technology too?
Share this post
Link to post
I do not use phone app
yes it's Bluetooth technology.
all very easy. IMHO.
near home entrance door working rPi. it monitors family iBeacons.
Share this post
Link to post
Just so that I understand better. I’m imagining a raspberry pi near the front door. When it detects the proximity of a tag then this flags someone is in.
Don’t they have a limited range?  If someone is at home but say in the garden are they at home or away? Perhaps you have lots of raspberry pis around the house that detect iBeacons?
Im interested as I have been trying to tackle this problem for along time.
Share this post
Link to post
Tried to use your VD with looks great but I am unable to get it running.
Keep getting the error message:
/monthly_2019_01/1920745726_Schermafdruk2019-01-0916_43_56.png.8439295364d1ab441ab681517c12452e.png" alt="1920745726_Schermafdruk2019-01-0916_43_56.png.8439295364d1ab441ab681517c12452e.png" />
And even without changing the mac addresses to my own mac addresses of my phones it shows that they are present.
Any idea?
Eric
Share this post
Link to post
Hi 10der,
I like to use your VD because the VD from the french forum is eating to much CPU.
But I do not get yours running.
I keep getting the same fault in the debug, see above screenshot.
Can you help me out?
Eric
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
