Secure Mode
Dunkigrease
I cannot arm some devices and I notice that they have the lock symbol which I gather means that Included them in secure mode.  Is it possible to undo the secure mode or do I have to delete the device and add it again?
Do you have more information about your setup ?
- Which gateway do you use
- Which firmware version do you use
- Since when does this occur,
- Dit you change anything on the settings  that might caused it ?
- Did you contact Fibaro support yet ?
I dont know if I can help you, but I think with these information, we will get a better overview for you and maybe can help you out on it ?
  • I am using Home Center Lite version 4.170.
    I bought all of the equipment and installed it in January but didn´t have to complete the installation fully before we went travelling for three months.  I am now getting back into it. I think this Lock Symbol appeared after I had installed the devices, but I can´t be certain.  I really don´t recall whether I installed some devices in secure mode and others in non secure mode.
    So I am not suggesting there is anything wrong with the system, I am just asking if the fact that a device has been added in secure mode should it stop me from arming it?   AND  if it is possible to remove the secure inclusion or do I have to reinstall those devices that are showing the lock.  By the way all of my devices are door sensors or motion sensors.  So I guess there is no need for any of them to be in secure mode.
