jacethesparky 0
OK i see in the latest update you can now use an installer access panel to allow installer to do remote work. tried setting up as per the instruction on the installer access panel. added new fibaro ID, logged in, and input installer email into the installer pane, comes up in red under neath must be a fibaro ID email, which it is as i created one already. No instruction anywhere, i thought this was pretty self explanatory but seems not to be so easy. what is the correct way and steps to do this/.
Many Thanks.
3 answers to this question
