How to control SOMFY motors with remotecontroll, with Fibaro
hansaroen
Hi,  I do have outside an awning with a Comfy motor.  This has a build-in receiver for my hand-hold remote control.  I would like to control this awning through a Fibaro Roller Shutter 2.  The only natural place for attachment is on the cord to the motor and this cord has only L+N+Ground.
Any suggestions how I can do this without buying a new motor ?
Edited by hansaroen
Hi @hansaroen, I'm not going to be useful I'm afraid.
Is there nothing nearer the motor with additional wire ? or plug that can be tapped into that goes to a wireless controller ? or is it all built into the motor ?
I think there are 2 versions a built in reciever, and an external reciever .. if it's built in it's beyond me.
Is yours a newer version cl900 or 920 ? ( might have just made that model up, I can't find the bookmark for the one I was looking at :| ), irrespective, mine are all older, and I have been thinking about replacing one of them, and saw the new wireless one, which  .. I assumed without looking into the specs at this early stage, would be able to be switched as well ..!
I have a mate with a wireless one and when we installed that it had a seperate RF control unit which fed the up down wires so you could control more than one window at a time, that may be an option to buying a new motor ?
You may find a breakout ( breakin ! ) box that is suitable somfy do a lot of variations on their product.
Mine are wired almost exactly ;
Good luck !
Cheers,
al.
" to "
Temat został przeniesiony z "
" do "
