Plank 1
I am trying to get a power reading from my energy monitor but am having lots of trouble trying to work out what code i need to use. I need to get a particular piece of info from this response I get.
I don't have any experience in coding don't have much idea, but a nudge in the right direction would be greatly appreciated.
The exact response from the http request is = [{"cid":"PWER","data":[{"1525674668000":746}],"sid":"740893","units":"kWm","age":6}]
my energy monitor is a efergy monitor.
is where I got the API details from."746" is the value I am trying to retrieve.
When I print (response.data) I get [DEBUG] 16:31:24: [{"cid":"PWER","data":[{"1525674668000":746}],"sid":"740893","units":"kWm","age":6}]
When I print json.decode(response.data) I get [DEBUG] 16:17:02: table: 0x9c41348 -- I don't know what this means
I tested the path here:
and can get the watt reading using this code "..data[0]*" in the json path expression field
Scene code i'm using. I just copied and pasted from another forum post by @Lambik to get the http request, I'l make my own code later if i can get this data out.
6 answers to this question
