Member account - features
Here's a brief explanation of what a user of a member account is able to do on the Forum:
-          Send files up to 102400 kB
You can easily send files to other members, as long as those files won't be larger than 102400kB.
-          Vote in polls
A member is able to vote in any of the polls that can be found in the special Polls subforum.
-          Use tags
Proper tags usage guarantees that a post would be easier to find in a forum and could result in it getting more attention from other users. Do not be afraid to use them. ;)
-          Use the rating system
A rating system is a way to appreciate other users and let the whole community know, who's the most helpful.
-          Edit their posts
You're always able to edit any of your posts. However, please, once your problem is solved, don't change it's content to "solved" as it's supposed to serve as help to others as well. ;)
-          Report content
If you see any behaviour that breaks the rules of our forum, please, report that post in order to inform one of the admins.
-          Edit their own profile
You can upload a profile photo with a size up to 300kB, it can even be animated. You can also upload a photo which will serve as your cover (up to 500kB).  Your profile is the place to express yourself. However, please, make sure that it won't offend anyone and break the Forum's rules ;)
-          Give 10 reputation points per day
A member has 10 reputation points to distribute freely on a daily basis.
-          Update their status
Pretty self-explanatory. But again, be sure to watch your manners ;)
-          Add signatures
A member is able to add a signature that would appear below every post that they create. It can contain up to 3 images (1080x128px), 40 links, and 30 lines of text.
-          Send messages to multiple users
A member is able to send a message to 45 other users and have 300 conversations stored in their messenger.
-          Create as many posts as they like
There is no daily limit to the number of posts created by a single user.
-          Deleting their own content
A member is able to delete their own status updates, files or conversations. However, they're not able to delete their posts as they are kept as a source of knowledge for other members of our community.
-          Upload attachments
You're free to upload as many attachments as you like, but a single file cannot be larger than 102400kB.
