[SOLVED]Alexa - FIBARO dimmer FGD212 not discovered
marbe
I use Alexa for long time. Now has my Fibaro dimmer FGD212 stop responding, and I cannot discover it. Other devices are working.
I deleted Fibaro Smart Home skill, and reenabled, all devices are included, but this one not.
Is some limitation for switches?
The switch is enabled, configured, visible, and normally working at fibaro apps and web access.
7 answers to this question
  • Yes, I made partly zwave device reconfiguration, but it not helped.
    What can I try more?
  • No, it is added in non secure mode. And it worked, but in last few weeks it disappear from Alexa discover.
    It is FGD212, FW3.5, but there are more slave devices for one FGD212 as expected (I wrote it early).
    In this case, I'm afraid you'd have to contact our support and solve this issue with them.
  • After complete reconfiguration I can device discover, solved.
    Hi, may I refresh the topic? It continiously happens that from time to time, very randomyl (once it is dimmer, once some relay) I also loose my devices from alexa. Wonder if this is alexa issue or HC2?
