kjetilhansen 7
I have a problem with my three wall plugs.. They keep turning off... They did not do this before, but after I installed the script I linked after this post they kept turning off when not in use... So whenever I want to use the dishwasher, dryer or my washing machine I need to start the fibaro app, navigate to rooms, find the wall plug, tap it so it turns on.
I did delete the scrip as I thought that this was what causing the problem, but no change after. Also, the script had an option of turning the plug off after use, but I did not enable that.
I have gone through my scenes, (I don't have many) and the plugs are not mentioned anywhere so them turning off is a mystery..
A side note; I have a Fibaro dual relay module that I have hooked up. This I had a script that it should turn itself off from 06:00 to 08:00 but I found a programming error in the way I programmed it (it worked great thoug) but that too is giving me a hard time. If I open the app it says the switch is ON, but there is no power, if i turn it OFF - ON in the app it works..
This scene is also deleted..
Does the HC2 keeps a backup of my scenes and refuse do delete them?
Suggestions?
5 answers to this question
