[SOLVED]Smart Meter reading with P1Monitor
evanbeem
Hi all,
The wife and I have done some work on getting  json data from a Raspberry PI, running PI1Monitor.
The Pi is reading the data from a smart meter P1 port and we built a virtual device that shows the meter readings in a VD screen.
I included the VD and LUA-code. It's not pretty, but it works.
We would like to take this to the next level, but here is where we need help.
- Would it be possible to change the VD so it delivers the current usage to the power metering of the HC2. Right now, we have only some switches and dimmers that are counted in the power panel and we would like to have all power usage visible and we're not so interested in the usage of individual lights. We could use "some" help with that.
- How can we add icons to the labels. We've seen some examples with beautiful screenshots, but we are stuck with plain text.
Feel free to use the code. We're happy to share it with you.
Regards, Erwin & Linda
Hi @evanbeem,
I use something similar. What I have done is the following. Basic idea is to use one of the z-wave modules which does not have an actual power usage measurement to store/report the difference between the total actual power (W) as reported by the p1/smartmeter and the total power usage as reported by the other zwave modules. This way fibaro will report the correct total kW/kWh, etc.
I have added some lines in your lua script to make this happen. I made edits line 45-63.
Hope this help. Rene.
Edited by ReneNL
  • Hi Rene,
    That's should probablly work! Will try it out and let you know. Thanks!
    Regards, Erwin
  • Hi Rene,
    I tried your solution and it works like a charm. I now have all power usage visible in my main fibaro screen, as intended.
    Thanks again! ;D
    Regards, Erwin
    A few remarks for other readers: the device I sent the data to, obviously needs to have a power attribute, so a switch, dimmer, etc.
    Also, you need to disable the display of all the other power values in that power grid, or you will get double readings.
    • evanbeem changed the title to [SOLVED]Smart Meter reading with P1Monitor
    • 2 months later...
    • 1 year later...
    hello,
    i downloaded the p1monitor to my raspberry pi and its working.
    i make the virtual device and changed the lua code for the right ip adress and device id.
    its not starting when i check the debug function it says:
    [DEBUG] 13:30:26: Error in calling apiV3basic.php ; apiStatus 404; apiErrorCode 0; apiResult
    404 Not Found
    nginx/1.14.2
    what could i do to make it work?
    thanks in advance
    I think Rene already did with:
    I just bought a Raspberry PI to experiment.
    interested in the Lua code. Mayby the Plugwise is also a Raspberry PI under the hood?
    Aha, You're connecting the PI directly to the Smart Meter?! Than the Plugwise will likely do something similar to make smart meter readings actually readable ;-)
    here's the lua code with many thanks to Mr. Hekker's blog:
    I have the idea that the json string of p1monitor is changed after a few versions.
    But i don't know how to change the lua script for the new json string.
    the old have this names:
    and the new have this:
    API lijst
    1. Please login or register to see this link.
    2. Please login or register to see this link.
    3. Please login or register to see this link.
    4. Please login or register to see this link.
    5. Please login or register to see this link.
    6. Please login or register to see this link.
    7. Please login or register to see this link.
    8. Please login or register to see this link.
    9. Please login or register to see this link.
    10. Please login or register to see this link.
    11. Please login or register to see this link.
    12. Please login or register to see this link.
    13. Please login or register to see this link.
    14. Please login or register to see this link.
    15. Please login or register to see this link.
    16. Please login or register to see this link.
    17. Please login or register to see this link.
    18. Please login or register to see this link.
    19. Please login or register to see this link.
    20. Please login or register to see this link.
    21. Please login or register to see this link.
    22. Please login or register to see this link.
    23. Please login or register to see this link.
    24. Please login or register to see this link.
    25. Please login or register to see this link.
    26. Please login or register to see this link.
    27. Please login or register to see this link.
    28. Please login or register to see this link.
    29. Please login or register to see this link.
    30. Please login or register to see this link.
    31. Please login or register to see this link.
    32. Please login or register to see this link.
    33. Please login or register to see this link.
    34. Please login or register to see this link.
    35. Please login or register to see this link.
    36. Please login or register to see this link.
    37. Please login or register to see this link.
    38. Please login or register to see this link.
    39. Please login or register to see this link.
    40. Please login or register to see this link.
    41. Please login or register to see this link.
    42. Please login or register to see this link.
    43. Please login or register to see this link.
    44. Please login or register to see this link.
    45. Please login or register to see this link.
    46. Please login or register to see this link.
    47. Please login or register to see this link.
    48. Please login or register to see this link.
    49. Please login or register to see this link.
    50. Please login or register to see this link.
    51. Please login or register to see this link.
    52. Please login or register to see this link.
    53. Please login or register to see this link.
    54. Please login or register to see this link.
    Last week i created the scriot below and works with the latest version.
    %% properties
    %% events
    %% globals
    -- Virtual device id
    vDevId = 71
    local vDevId = fibaro:getSelfId();
    --fibaro:debug(vDevId);
    -- url van PI met meterconnectie
    PI1 = Net.FHttp("ipadres");
    PI1:setBasicAuthentication("smile", "id nummer smile");
    -- ophalen JSON info
    response, status, errorCode = PI1:GET("/core/modules");
    --fibaro:debug(response);
    --fibaro:debug(status);
    --fibaro:debug(errorCode);
    -- Meter info ophalen
    local a = string.match(response, "^.+<vendor_name>(.+)</vendor_name>.+$");
    local b = string.match(response, "^.+<vendor_model>(.+)</vendor_model>.+$");
    local c = string.match(response, "^.+<modified_date>(.+)</modified_date>.+$");
    local d = string.match(response, "^.+<created_date>(.+)</created_date>.+$");
    --fibaro:debug("vendor name :" .. a);
    --fibaro:debug("vendor_model :" .. b);
    --fibaro:debug("modified date :" .. c);
    --fibaro:debug("created date :" .. d);
    local e = string.match(response, "unit='W' directionality='consumed'>(.+)</measurement>.+$")
    local VerbruikActueel= string.match(e, "(%d+.%d+)");
    local e = string.match(response, "unit='W' directionality='produced'>(.+)</measurement>.+$")
    local LeveringActueel= string.match(e, "(%d+.%d+)");
    local e = string.match(response, "unit='Wh' directionality='consumed' tariff_indicator='nl_peak'>(.+)</measurement>.+$")
    local VerbruikHoog= string.match(e, "(%d+.%d+)");
    local e = string.match(response, "unit='Wh' directionality='consumed' tariff_indicator='nl_offpeak'>(.+)</measurement>.+$")
    local VerbruikLaag= string.match(e, "(%d+.%d+)");
    local e = string.match(response, "unit='Wh' directionality='produced' tariff_indicator='nl_peak'>(.+)</measurement>.+$")
    local LeveringHoog= string.match(e, "(%d+.%d+)");
    local e = string.match(response, "unit='Wh' directionality='produced' tariff_indicator='nl_offpeak'>(.+)</measurement>.+$")
    local LeveringLaag= string.match(e, "(%d+.%d+)");
    -- totaal tellers (dag+nacht-teruglevering)
    local ActueelTotaal = VerbruikActueel - LeveringActueel
    local MeterTotaal = VerbruikHoog + VerbruikLaag - LeveringHoog - LeveringLaag
    -- omzetten naar decimalen
    local VerbruikActueel = tonumber(string.match(VerbruikActueel, '%d+'))
    local LeveringActueel = tonumber(string.match(LeveringActueel, '%d+'))
    local VerbruikHoog = tonumber(string.match(VerbruikHoog, '%d+'))/1000
    local VerbruikLaag = tonumber(string.match(VerbruikLaag, '%d+'))/1000
    local LeveringHoog = tonumber(string.match(LeveringHoog, '%d+'))/1000
    local LeveringLaag = tonumber(string.match(LeveringLaag, '%d+'))/1000
    local ActueelTotaal = tonumber(string.match(ActueelTotaal, '%d+'))
    local MeterTotaal = tonumber(string.match(MeterTotaal, '%d+'))/1000
    -- afronden op 2 decimalen
    local VerbruikHoog = string.format("%.2f", VerbruikHoog)
    local VerbruikLaag = string.format("%.2f", VerbruikLaag)
    local LeveringHoog = string.format("%.2f", LeveringHoog)
    local LeveringLaag = string.format("%.2f", LeveringLaag)
    local MeterTotaal = string.format("%.2f", MeterTotaal)
    --fibaro:debug("Elektriciteit actueel verbruik :" .. VerbruikActueel);
    --fibaro:debug("Elektriciteit actueel levering :" .. LeveringActueel);
    --fibaro:debug("Elektriciteit Meter verbruik Hoog :" .. VerbruikHoog);
    --fibaro:debug("Elektriciteit Meter verbruik Laag :" .. VerbruikLaag);
    --fibaro:debug("Elektriciteit Meter levering Hoog :" .. LeveringHoog);
    --fibaro:debug("Elektriciteit Meter levering Laag :" .. LeveringLaag);
    fibaro:debug("Elektriciteit Meter Actueel Totaal :" .. ActueelTotaal);
    --fibaro:debug("Elektriciteit Meter Totaal :" .. MeterTotaal);
    -- update virtual device
    fibaro:call(vDevId, "setProperty", "ui.ActueelTotaal.value", ActueelTotaal.." Watt");
    fibaro:call(vDevId, "setProperty", "ui.MeterTotaal.value", MeterTotaal.." kWh");
    fibaro:call(vDevId, "setProperty", "ui.VerbruikHoog.value", VerbruikHoog.." kWh");
    fibaro:call(vDevId, "setProperty", "ui.VerbruikLaag.value", VerbruikLaag.." kWh");
    fibaro:call(vDevId, "setProperty", "ui.LeveringHoog.value", LeveringHoog.." kWh");
    fibaro:call(vDevId, "setProperty", "ui.LeveringLaag.value", LeveringLaag.." kWh");
    -- ff 3 seconden slapen
    fibaro:sleep(3000)
    %% properties
    %% events
    %% globals
    vDevId = 71
    fibaro:sleep(3000)
    is this code for p1monitor or the plugwise smile?
    i like to connect my raspberrypi with p1monitor to my hc2.
    so my totalpower usage from the meter is displayed on the original page of the hc2.
    On 5/27/2018 at 10:20 PM, ReneNL said:
    Hi @evanbeem,
    hi Rene,
    do you still have this working on your Raspberry PI ?
    3 hours ago, ReneNL said:
    Yup, still working perfectly.
    what software and version do you have on the raspberry pi?
