[SOLVED]Smart Meter reading with P1Monitor
evanbeem
You could use something like this:
for 3 decimals behind the komma (or dot).
Hi Eddy,
Thanks for the reply, however I am not a programmer like you so where should I put that?
The VD gets the values from the variables in that strange long way..
Eric
My neither
Can you post the code you use? Then we can insert the example code "prod_high = string.format("%.3f", prod_high)" in the right place and context.
Hi Eddy,
Here the LUA from the main loop.
588 is my VD with gives me the info from the variables which are pushed from Domiticz-Fibarolink.
590 is my dummy Poer switch which I only use to get the energy readings in the Fibaro Energy Panel.
As you can see in my previous post, I can see The "Stroom"  and other readings in a label but with a weird long number.
I wand a Clean nummer to read and then send that to my dummy switch.
fibaro:call(588, "setProperty", "ui.Label1.value", tostring(fibaro:getGlobalValue("Gas")));
fibaro:call(588, "setProperty", "ui.Label2.value", tostring(fibaro:getGlobalValue("KamerTemp")));
fibaro:call(588, "setProperty", "ui.Label3.value", tostring(fibaro:getGlobalValue("Stroom")));
fibaro:call(588, "setProperty", "ui.Label4.value", tostring(fibaro:getGlobalValue("Water")));
-- START OF LINES I ADDED
--  local i=0
--    local total_devices = 0
--    local maxNodeID = 350 -- maximum node ID in your z-wave network
--    local deviceValue = 0
--    local delta_power = 0
--    local powerID = 590 -- change to ID where you want to capture the 'delta' power
--    for i = 0, maxNodeID do
--        if fibaro:get(i, 'power') ~= nil and i~=powerID then
--            deviceValue = fibaro:get(i, 'power')
 --           total_devices = total_devices + deviceValue
--        end
--    end
--    delta_power = tonumber(Stroom) - total_devices
    --fibaro:debug(delta_power)
--    api.put("/devices/"..powerID, {["properties"]={["power"]=delta_power}})
-- END OF LINES I ADDED
And here is the VD I use
Should be something like this, to prevent the weird numbers:
5 hours ago, Wiers99 said:
fibaro:call(588, "setProperty", "ui.Label1.value", string.format("%.3f", fibaro:getGlobalValue("Gas")));
fibaro:call(588, "setProperty", "ui.Label2.value", string.format("%.3f", fibaro:getGlobalValue("KamerTemp")));
fibaro:call(588, "setProperty", "ui.Label3.value", string.format("%.3f", fibaro:getGlobalValue("Stroom")));
fibaro:call(588, "setProperty", "ui.Label4.value", string.format("%.3f", fibaro:getGlobalValue("Water")));
--  local i=0
--        end
--    end
(If you want two decimals, just change the 3f in a 2f)
That worked on the "normal" numbers and I can adjust it like you mentioned.
However the "Stroom" and "Kamertemp" are send by Domoticz by a strange "%20" at the end.
How can I clean that up?
2021-11-04 20:27:57.274 FibaroLink: sending global variable Water with value: 184330
2021-11-04 20:28:00.690 FibaroLink: sending global variable Stroom with value: 425.0%20Watt
2021-11-04 20:28:00.739 FibaroLink: sending global variable Gas with value: 344.435
Looks like a space character. If Domoticz can’t solve it, you could solve it more the hard way ?
Stroom = string.gsub( “”, ”%%20”, Stroom)
Put it on top of the code ??
Edited by SmartHomeEddy
if I put it on top of the code I get:
[ERROR] 22:11:54: line 2: unfinished string near '"”, ”%%20”, Stroom)'
@Wiers99 Looks like the quotes aren’t ok. I think the forum messes them up.
Please replace the quotes with the double quotes.
(Two double quotes before the komma and double quotes around the %%20)
  • 4 weeks later...
Hi Eddy, sorry for the late reaction but have been rather busy lately.
Putting double quotes gave me the following debug:
[ERROR] 11:19:22: line 2: unexpected symbol near '%'
I have been using the modified "slimme meter" VD instead and that works OK but because of my TOON keeps restarting and sometimes disconnecting from my wifi, the VD stops working.
Also there is too much information in the VD, I only need the Stroom usage to display.
This is what works so far...
--  Toon Data v0.23 for a rooted toon by fkruis ™.
--  fill in the headers the ip and port number of your toon (port number is normally 10080 or 80).
---------------------------- user adjustable parameters ----------------------------------------------
local Standaard_debug_info  = false; -- Debug in geel.
local Extra_debug_info      = true;  -- Debug in oranje.
local Test_debug_info       = false; -- Debug in rood.                 -- polling time, default is 1 minute
local SleepTime = 10;                -- polling time, default is 10 minutes
------------------ local settings ----------------------------
local ThisModule=fibaro:getSelfId();
local _IPAddress = fibaro:getValue(ThisModule, "IPAddress" );
local _TCPPort = fibaro:getValue(ThisModule, "TCPPort" );
Toon = Net.FHttp( _IPAddress, tonumber( _TCPPort ));
local ElecUsage = 0;
local ElecProduction = 0;
local ElecDeliveredNt = 0;
local ElecDeliveredLt = 0;
local TotalElecDelivered  = 0;
local GasUsage = 0;
local TotalGasUsage =0;
local Date = os.date("%d-%m-%Y");
local Time = os.date("%H:%M:%S");
--------------------- funcions -------------------------------
Debug = function ( Kleur, Bericht )
 fibaro:debug( string.format("<%s style='color:%s;'>%s</%s>", "span", Kleur, Bericht, "span" ) );
Standaard_debug = function ( Bericht )
if ( Standaard_debug_info )
   then Debug( "yellow", Bericht);
Extra_debug = function ( Bericht )
if ( Extra_debug_info )
   then Debug( "orange", Bericht);
Test_debug = function ( Bericht )
if ( Test_debug_info )
   then Debug( "red", Bericht );
--------------------- begin scene ---------------------------
Test_debug(" The ThisModule value is ".. ThisModule );
Test_debug(" The _IPAdress value is " .. _IPAddress );
Test_debug(" The _TCPPort value is " .. _TCPPort );
---------- getting elec_quantity_ntdsta from toon -----------
local response, status, errorcode = Toon:GET( "/hcb_rrd?action=getRrdData&loggerName=elec_quantity_nt&rra=5yrhours&readableTime=1&nullForNaN=1&samples=1&from=".. Date .."" );
if errorcode == 0
   then fibaro:log(" Verbonden " );
        Test_debug(" The status value of Toon:GET is " .. status );
        else Test_debug (" The errorcode of Toon:GET is " .. errorcode );
             fibaro:log (" Verbindings fout! " );
             Extra_debug(" There is no connection with toon! please check your settings " );
             _abort = true;
if _abort
   then Extra_debug (" The Scene is stopped because of error " .. errorcode )
        fibaro:log  (" The Scene is stopped" );
        fibaro:abort()
Standaard_debug (" The response values of Toon:hcb_rrd are ".. response );
local response = ( response:gsub(".*:",""))
local response = ( response:gsub("}",""))
local ElecDeliveredNt = response
---------- getting elec_quantity_lt dsta from toon ----------
local response, status, errorcode = Toon:GET( "/hcb_rrd?action=getRrdData&loggerName=elec_quantity_lt&rra=5yrhours&readableTime=1&nullForNaN=1&samples=1&from=".. Date );
if errorcode == 0
             _abort = true;
if _abort
        fibaro:abort()
local ElecDeliveredLt = response
local TotalElecDelivered = ElecDeliveredNt + ElecDeliveredLt;
------------------- Debug ------------------------------------
Extra_debug (" The value of ElecDeliveredNt is " .. ElecDeliveredNt .."" )
Extra_debug (" The value of ElecDeliveredLt is " .. ElecDeliveredLt .."" )
Extra_debug (" The value of TotalElecDelivered is " .. TotalElecDelivered.."" )
---------- Getting GetCurrentUsage data from toon -----------
local response, status, errorcode = Toon:GET( "/happ_pwrusage?action=GetCurrentUsage" );
if errorcode == 0
             _abort = true;
if _abort
   then Extra_debug(" The Scene is stopped because of error " .. errorcode )
        fibaro:abort()
Standaard_debug (" The response values of Toon:GetCurrentUsage are ".. response );
local JsonToon = json.decode(response);
------------ converting toon data ---------------------------
local ElecUsage =(JsonToon.powerUsage.value);
local ElecProduction = (JsonToon.powerProduction.value);
local GasUsage = (JsonToon.gasUsage.value);
fibaro:debug (GasUsage)
if (JsonToon.gasUsage.value == json.null)
    then GasUsage = 0;
Extra_debug(" The value of Electricity Usage is " .. ElecUsage )
Extra_debug(" The value of Electricity Production is " .. ElecProduction )
Extra_debug(" The value of Gas Usage is " .. GasUsage )
--------- Getting gas_quantity data from toon ---------------
local response, status, errorcode = Toon:GET( "/hcb_rrd?action=getRrdData&loggerName=gas_quantity&rra=5yrhours&readableTime=1&nullForNaN=1&samples=1&from=".. Date );
if errorcode == 0
             _abort = true;
if _abort
        fibaro:log (" The Scene is stopped " );
        fibaro:abort()
Standaard_debug (" The response values of Toon:/hcb_rrd are ".. response );
---------------- converting toon data  ----------------------
local response = (response:gsub(".*:",""))
local response = (response:gsub("}",""))
local response = (response:gsub("null","0"))
local TotalGasUsage = (response)
Extra_debug (" The value of TotalGasUsage is " .. TotalGasUsage )
------------------ Set property labels -----------------------
fibaro:call(fibaro:getSelfId(),"setProperty","ui.ElecUsage.value",tostring(ElecUsage ));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.ElecProduction.value",tostring(ElecProduction));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.ElecDeliveredNt.value",tostring(ElecDeliveredNt ));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.ElecDeliveredLt.value",tostring(ElecDeliveredLt));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.TotalElecDelivered.value",tostring(TotalElecDelivered, "KWH"));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.GasUsage.value",tostring(GasUsage));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.TotalGasUsage.value",tostring(TotalGasUsage));
fibaro:call(fibaro:getSelfId(),"setProperty","ui.RefreshTime.value",tostring( Time ));
----------------------------- wait time until next polling --------------------------------
fibaro:sleep(12000);
  local i=0
    delta_power = tonumber(ElecUsage) - total_devices
This gives me a working energy panel in the fibaro app with an update every 20 seconds until the the wifi from TOON disconnects or a fault with "Elecproduction" kicks in.
I tried to remove as much as possible information which I do not need but than the VD stops working.
Can this VD be modified into something simple so that it only gives me the "ElecUsage"?
Eric
Eddy, your my hero!
Working great so far.
Now waiting how the connection with the TOON holds up.
Thanks for helping me out.
Eric
It is working great until it disconnects from TOON due to some hiccup.
Then I have to restart?save the VD and it is back to normal.
I there  a simple solution so that it is trying to reconnect when the connection with TOON temporarily stops?
@Wiers99 Not that familiar with the VD’s. I would delete (put comment -- in front of it) this code:
or comment out
  • 1 month later...
Still working great!
Found the problem with the constant  restarting Toon, it was the app that monitors the Boilerstatus.
This was overflowing the memory so it kept restarting and made the Toon very slow to react.
So I removed the app and now hardly any restarts and a quick responding Toon.
Still a question:
Can I Turn on the "show energy consumption measurements" on the individual light switches etc without adding this to the total consumption of the dummy?
Will this part     (delta_power = tonumber(ElecUsage) - total_devices) in the VD take care of it?
Because I like it when you can see also the individual power consumption of the switches etc.
good to hear it works and Toon is running ok again
yes,
in this part:
the energy usage from all your power consumption devices is deducted from the Toon measured total energy consumption (to put the “rest” energy consumption, not directly recorded by the HC2, in a “spair” device).
So the HC2 can show all energy usage from power devices and the from your “spair” device with the “rest” power consumption.
