Teza 3
I have two block scenes that works, and when I change these from block to LUA, I get the following code:
Scene 1: Set variable value if movement
Scene 2: Set variable value if no movement
Trying to combine these into one LUA scene, I wrote the following code:
Question #1:
This creates the following error: [DEBUG] 12:23:15: [1;31m2018-05-27 12:23:15.977459 [ fatal] Unknown exception: /opt/fibaro/scenes/104.lua:49: unexpected symbol near ')'
What did I miss?
Code line #46 to #50 is;
Question #2:
What is the purpose the number in the following codeline, in scene #2 above?
Question #3:
What does this codeline from scene #1 and #2 do?
Solved
12 answers to this question
