emielw 0
I'am new to the Fibaro community so first of all: hi!
I’m having problems with pairing my shutter FGR222 to Fibaro home center.
I already searched for similar problems, but no solutions yet. Hopefully you can help me.
When I put my HC2 in learning mode and press the “B-button” for three times nothing is happening.
What I tried:
Switch connected to the s1 input pressed for three times -à nothing happens
Only connect supply voltage and press B-button for three times à nothing happens
I bought this device second hand so it could be the device is broken. Is there a way to check this?
Some additional information:
Home Center is next to the FGR222, so it’s in range. (I can connect to a motion sensor)
When I press the B-button longer à first I get a blue light, after a few seconds it gets green. No other colors after that.
According the manual it should reach other colors.
Hopefully someone can help me. Thank you in advance.
Emiel
