Hi - Brand new to this. I have an HC2 and Harmony Hub. Both were working well until recently where connection was lost. I factory reset the Harmony and attempted a reload of the Harmony Hub Plugin.
The plugin loads and i am able to get the Harmony Pin. On copying and saving it to the HC2 i get the message "Undefined error" Further attempts also fail.
Has anyone had this problem and is there a solutioin?
Cheers
Andrew
I have the same issue, but i have not find a solution, any ideas anybody?
I have the same issue.
t
Have same issue
Same issue here, used to work flawlessly but stopped working on tuesday. Tried to reset the password, reboot of the HC2 and the Harmony Hub, reinstall of the plugin, nothing seems to work.
i guess logitech made some changes to their platform and updated harmony remotely....
Same issue. I hope now we can control devices individually and not just Activities!
Fibaro team any update on that?!
Same issue over here. I hoped I would find a solution for remote controlling my Ziggo Horizon Box...
Through Harmony it works, but no connection with Fibaro.... That s@@@@s
Answer from support:
  29 Jun 18
There is a problem with compatibility with the Logitech plugin since the last upgrade of Harmony.
Our developers are already on the issue.
I apologize for the inconvenience
Pozdrawiam / Best regards
Thanks for sharing info
  29 Jun 18
thnx for info
Will there be a fix in the new 4.503 Version?
Current beta does not fix the problem.
Yes, it works again!
yes it works again, but I have issues with activities status.... is it the same for you???
Hello how to create scene with Harmony.
i want for exemple receive notification when someone use the TV lol
I bought an Harmony Elite remote controller.Yesterday I configured and I still have the issue you reported. Anything shall I do to overcome it? Thanks a lot
Undefined error. Please generate a new Pin Code in the „Advanced” tab and press the „Save” button.
Edited by dancar
Did you generate Pin Code correctly? I mean your harmony account OK?
Yep, My account is ok (connected via Google account). And the PIN is correctly generated. I'm running 4.560 SW.
I tried several time, always the same error.
The remote controller is working fine, with all activities and device I configured. Sad when I saw it not working with my Fibaro.
