router compatibility
ayush kohli
i have a dlink DSL-2750U Wireless N 300 ADSL2 + Router. can i use with home center lite or home center 2 ? will it work properly?
1 answer to this question
It should work, why would not?
I found that only routers from UPC (
here in CZ have problem to assign IP adress after they power cycle and HC not. To make HC obtain IP adress customers must reboot routers. Routers are made by Ubee.
And i think it is issue in the router, since with others it seems to work. Tested with Netgear, Pakedge and Ubiquity Unifi Security Gateway.
