Is there a maximum fibaro:sleep time?
clowg
Is there a maximum time that fibaro:sleep can be set to?
I'm having a problem where  'fibaro:sleep(90*60*1000)' only lasts for 20 minutes, not 90 minutes as I expected it would.
However fibaro:sleep(30*60*1000) works fine - 30 minutes.
I'm using these within a VD, in case that makes a difference.
9 answers to this question
  • But that’s only 5.4 seconds. I want 90 minutes sleep time.
    offcourse my mistake
    and
    local timeSleep = 90
    function timerFunction()
    code
    setTimeout(timerFunction, timeSleep*60*1000)
    timerFunction()
  • I'm not sure if the use of seTimeout can work in my case.
    This is the code for a button in a VD that should turn on the air-con and run it for 90 minutes if its off, and if it's already on, then turn it off.  I've attempted to use your setTimeout & function idea, but it doesn't look right.   (I've used a lot of debug messages to try to track whats going on & why it doesnt sleep for 90 minutes)
    What do you think?
    Edited by clowg
    Timerfunction does not work in a VD button
    If i am right you want a vd button to set your AC on for 90 min (manualy) and when time is done its turn off
  • Oh.
    Yes - thats right.  This is a VD that is used to manually control the AC.  I have buttons for 30, 60 & 90 minutes run time.
    i also have a ac
    made script for schedule of nightshift compare with temp
    or set it manualy 1 - 2 or 4 hours
    or set it in mainteness
    wil placeit here
  • THAT looks very interesting @Kage!!  Please do share what you can.
    This is a little bit personal script but you can change the names in the VD and the scene
    you have to make two globals eg.
    AC_Status_Master
    ACManueel_Master
    I combined also our phone(s) in the script and our schedule so it knows if we are home or not and when to go on if whe haven nightshift and its to "hot"in the room
    Also you can trigger it manualy for 1 - 2 - 4 hours its stops when it is time
    Also maintenance is availble, you can do what you whant
    it stops when manualtime is over
    it stops if you are not home
    it stops when the temp is lower then ........
    it stops when the door is open or window
    it stops if you not in bed
    if you need help let me know. mostly it is dutch
    /monthly_2018_07/onderhoudt.png.0e4906261118a8b6c36c0cec77ce14b1.png" />395295249_Aricoonoff.png.0988c243aa639df3781c18f86afc275e.png108518866_Aircouit.png.272a7299d63c2b5b4a74c051f949709d.png77895475_Aircoon.png.38f55ace7d71fe80f1bc600c8320d3f9.png1438789119_Aircoonoff.png.560af8db9696df49a2585d09fdd33c5a.png823764936_Aircooff.png.5a0f1db13633f7f16353ffdae851b72c.png837163285_Aircoautoon.png.13af0c7d200a1ef521655b677c69dde4.png1497486376_Aircoautoonoff.png.321562f72a48b88055265da27cd8d17a.png1712447643_Aircoautooff.png.48c4aa6a0a042ecaa5ec3f5ee2f5989e.pngAfwezig.png.6d090a583824a63b0ec0a51be3633991.png
    it is working whit a fibro wallplug and a ZXT-120 remotec (ir)
    Edited by Kage
