Missing room with foscam generic plugin in Fibaro App (android)
hurricanet
Hi everyone!
I have an issue regarding the rooms' appareance in Fibaro mobile app (android). The thing is that I created a room (i.e. bedroom) and only the foscam device was assigned to it. In the web UI I can see this room as same as others, although no feature is highlighted on it such as with lighting devices. However, in the Fibaro mobile app, I can not see this room under "rooms tab".
For the device inside this room I use a generic plugin (Foscam generic) and in the advanced tab there is no information about ID, Device Type and so on. I think the problem is due to this plugin which is not properly recognized by the Fibaro app but I want to ask you to be sure and if there is any solution to solve it. With this plugin I can not set many more parameters except those related directly to the cam device. So my questions:
1. Is due to the Foscam generic plugin?
2. What can be done in order to see this room in the fibaro mobile app with only the foscam device?
By the way, the Foscam device is 9826P.
Thanks so much in advance.
Best regards
