HCL, the scenes works sometimes
rammx
Hello, I have HCL with 4.504 Beta firmware.
I made 2 scenes to turn on the light when I arrived at home at the night, but sometimes the lights turns on on the day and sometimes turn on on the night or when a leave the home the lights turn on by it self.
The only thing that I need it's turn on the lights between 18:45 - 05:45 hrs. just if I open the garage door.
This is the original programmation:
After
Modification.
After:
The HCL have to many instances (notificacion) I changed the programmation, I put only one thing to do and have the same notificacion, I put "if this happen then do this" but sometime works or some times "to many instances"
If somebody have some advice I would appreciate it a lot.
Read the descriptions of the categories:
Quote
Forum
Do you have a suggestions about the Forum? Any comments about the Forum? This is the place!
Your thread does not belong to the category.
Also, get familiar with the guides on the Forum, like this one below:
