Hi @jgab
I see two now one more issues i my setup.
First i this error
for
second - I dont see any pust messages on my phone anymore. is running on Beta FW - is syntax new or should i look somewhere else ?
I'm still using User = 2
Edited by ChristianSogaard
P
1 hour ago, ChristianSogaard said:
Hi again
I see two more issues i my setup.
First i this error
for
not your username
Try it with your device ID
my notifications arrive well
/monthly_2021_07/258682086_2021-07-19175521.png.a1fd0b39496beac91578c5e9f3e2c3d1.png" />
Edited by minsad79
13 minutes ago, minsad79 said:
not your username
Thank you this works  - this is working. strange i need to change it from the user to the device
P
  • The alarm error is confirmed It happens when you disarm the whole house?
    Seems to be same problem as @Sjakie has.
    I'm looking into it.
  • Pushed v0.5fix69 that fixes the problem with disarming the whole house.
    Jan, hereby
    //Sjakie
    Yes if arm complete complex>> I dont use it often.
    I discoverd that it contained an error is fixed now so it can be used.
    Thanks,
    //Sjakie
    Note:
    If I now arm / dis arm comlex result>>>NO error!!
    Thanks,
    //Sjakie
    rd
    I am using device ID since months for push messages. Fibaro doest know what they do with pushmessages.
    //Sjakie
    Can You please tell me why from some time for this rule i got such an error?
    rule("trueFor(00:10,ruchpiwnica:safe) & drzwipiwnica:isOff & 3:alarm.armed == false => fibaro.alarm(3,'arm');log('Automatyczne uzbrojenie alarmu w piwnicy');again()").start()
    [21.07.2021] [23:09:37] [ERROR] [QUICKAPP453]: Error in 'trueFor(00:10,ruchpiwnica:safe) & drzwipiwnica:isOff & 3:alarm.armed == false => fibaro.alarm(3,'arm');log('Automatyczne uzbrojenie alarmu w piwnicy');again()': ./include/EventRunner.lua:2035: attempt to concatenate a nil value (upvalue 'pn')
    [21.07.2021] [23:09:37] [ERROR] [QUICKAPP453]: main() error:./include/EventRunner.lua:2346: Main() ERROR:./include/EventRunner.lua:2181: ./include/EventRunner.lua:2035: attempt to concatenate a nil value (upvalue 'pn')
    Well, it's actually a bug.
    I'm trying to make a trigger out of "3:alarm.armed" and fail. The reason is that <id>:alarm is not really meant to be used as a trigger. In any case I have fixed it in the next version so it doesn't generate an error.
    So what should you use?
    The below tests should be used an work as triggers. Note the semantic when applied to one partition and a list of partitions:
    <id>:armed return true if partition id is armed
    {<id1>,<id2>,...}:armed return true if any partitions in list is armed
    {<id1>,<id2>,...}:allArmed returns true if all partitions in list is armed
    <id>:disarmed return true if partition is disarmed
    {<id1>,<id2>,...}:disarmed return true if all partitions in list is disarmed
    {<id1>,<id2>,...}:anyDisarmed return true if any partition in list is disarmed
    <id>:alarmBreached return true if partition is breached
    {<id1>,<id2>,...}:alarmBreached return true if partition is breached
    <id>:alarmSafe return true if partition safe
    {<id1>,<id2>,...}:alarmSafe return true if all partitions in list is safe
    {<id1>,<id2>,...}:allAlarmBreached return true if all partitions in list is breached
    {<id1>,<id2>,...}:anyAlarmSafe returns true if any partition in list is safe
    <id>:willArm returns true if partitions will arm soon
    {<id1>,<id2>,...}:willArm returns true if any partition in list will arm soon
    {<id1>,<id2>,...}:allWillArm returns true if all partitions will arm soon
    Also there are some actions (can not be used as rule triggers)
    <id>:alarm=true  arm partition
    <id>:armed=true  arm partition, same as previous
    <id>:alarm=false  disarm partition
    <id>:armed=false disarm partition, same as previous
    <id>:alarm=watch start to watch alarm being activated - will generate 'willArm' events
    <id>:alarm=unwatch start to watch alarm being activated - will generate 'willArm' events
    So your rule should be written
    rule("trueFor(00:10,ruchpiwnica:safe) & drzwipiwnica:isOff & 3:armed==false => 3:armed=true;  log('Automatyczne uzbrojenie alarmu w piwnicy');again()").start()
    Note that you can also use just 3:disarmed instead of 3:armed==false
    Jan, is there a possibility that if I use  trueFor(00:00:30,......) it can count  down in debug the seconds?
    //Sjakie
    //Sjakie
    No, that's not how trueFor works. The rule is only called when the expression changes value or when the time is up. There is no second timer ticking.
    Ok, thanks.
    Can it be done with wait? To see a count down in debug?
    //Sjakie
  • It depends on how you want to use it. together with trueFor it's difficult as it can restart if condition becomes false.
    Just creating a timer is easy
    Ex.
    rule([[#countDown{val='$val>0'} & !stopCountDown => log('Count down %s',val); post(#countDown{val=val-1},1) end
    Ex. rule("wait(2); stopCountDown=false; post(#countDown{val=10})") -- Start count down
    Ex. rule("wait(5); stopCountDown=true") -- Stop count down early
    Jan, thanks but I will forget it because trueFor is the best option.
    I have an error in setting Sonos parser error and illegal assignement
    //Sjakie
    //Sjakie
    Well, I had another look at the trueFor code and I think I found a way to do it.
    I pushed fix71 with the new feature.
    In short it works like this
    If you save the rule in a global lua variable ('r' in this example) you can define an event trigger
    #trueFor{rule=r} => ...
    that will trigger whenever the rule's trueFor start watching the expression, stops, and expires.
    Every time the trueFor expression becomes true it will start to watch the expression for the given time.
    If the expression turns false before time expired it will stop
    If the expression is true for the given time it will 'expire' and run the action.
    The #trueFor event will fire when it starts, stops, and expires.
    The expire event will look like
    #trueFor{rule=r,stop=true,expired=true} so you can test on either stop or expired.
    You can try the example above to get a feel for how it works.
    Ex. here is a rule to count down while the trueFor is true...
    Jan, I am doing it wrong I dont see nothing in debug
    I have fix 71
    create GV standard variable r value
    Please advice
    //Sjakie
    I have fix 71
    Please advice
    //Sjakie
    r should be a Lua global
    Jan, my QA location was on fix 64, after update fix71 I get parser error.
    Please advise,
    //Sjakie
    Jan, thanks!
    this rule gives wrong debug, should be partition 26
    //Sjakie
