On 10/10/2021 at 2:40 PM, jgab said:
You should be able to run it in my emulator.
In
function EVENTS.getIOSdevices(ev)
there is a http request.
Set a breakpoint in the error and the success handler and see what you get, if you get something.
Hi Jan
I loaded the IOSLocator in ZBS - but im getting issue at line 392 - im pretty sure this is something else, that the error when the QA is running.
  • 11 hours ago, ChristianSogaard said:
    Hi Jan
    This is strange - it seems like it hasn't loaded fibaroExtra.lua ? on the other hand if fibaroExtra.lua didn't exist it would complain....? Let me think about this...
    Confirming that, fibaroExtra.lua is missing, i dont see its possible to "enable" in the toolbox?
    Where in ZBS do i put the fibaroExtra.lua? for it to work with IOSLocator?
    Tried using the "mini-installer" in the IOSLocator.lua, and looking in the Proxy IOSLocator QA, i see the fibaroExtra.lua
    but i still are getting the same error...
    Edited by ChristianSogaard
    P
    I created this rules for my SONOS Connect and Denon amplifier.
    This will let HC3 detect when SONOS is playing and turn on the Denon amplifier. - i found the
    in the frensh forum
    It works, but i want it a little bit smarter
    I tried to create a rule for NOT PLAYING - like ...,value=!'PLAYING' or ...,value<>'PLAYING' - how is the syntax for this?
    What i really want is a TurnOff rule being activated when 'PLAYING' not has been active for 120 Seconds - what direction should i go for this?
  • Please login or register to see this code.
    If the state is set to "PLAYING" it will call :on
    If the state is set to something else then "PLAYING" for 120s it will call :off
    Does that work for you?
    no - i tried the "1282:state=='PLAYING'" myself, but i fails.
    And Yes to your answer if understood correct ;-)
    My triggers looks like this
    [31.10.2021] [14:00:26] [DEBUG] [QUICKAPP1102]: ------------------------------------- Setting up rules (main) -------------------------------------
    [31.10.2021] [14:00:26] [ERROR] [QUICKAPP1102]: Error in '1282:state=='PLAYING' => 1074:on': ./include/EventRunner.lua:2057: attempt to index a nil value (field '?')
    [31.10.2021] [14:00:26] [ERROR] [QUICKAPP1102]: main() error:./include/EventRunner.lua:2369: Main() ERROR:./include/EventRunner.lua:2204: ./include/EventRunner.lua:2057: attempt to index a nil value (field '?')
    P
    This works
    rule("#device{id=1282,property='state',value='PLAYING'} => fibaro.call(1074, 'turnOn')")
    This Complie and Dont work - 1074:On is not working
    rule("#device{id=1282,property='state',value='PLAYING'} => 1074:On")
    This dont Compile - it dont like the state=='PLAYING'
    rule("1282:state=='PLAYING' =>fibaro.call(1074, 'turnOn')
    This Compile and Dont work, it dont show or trigger after 2 min..you see the "PAUSED_PLAYBACK" in line 4
    rule("trueFor(00:02,#device{id=1282,property='state',value~='PLAYING'}) => fibaro.call(1074, 'turnOff')")
  • Hmm, I had forgot to add ':state' property to the rule engine.
    I pushed fix79. Try again with
    ':on' it's important that it's lower case letters. In your example you use ':On'
    x:on is translated to fibaro.call(x,"turnOn") so it must work.
    Yes . Now it works .-)??
    Did you also see my response from last day ?
    Yes, I'm restructuring my github directory now.
    In fact there is a new repository named TQAE with the emulator and the most common QAs I have posted here - like EventRunner4 and ChildrenOfHue - all updated for TQAE - all packed in a directory where everything should work together.. ;-)
    Here is also the new version of EventRunner that's based on fibaroExtra.lua - I would not recommend to use it at the moment - I'm running it myself and try to catch the obvious bugs... I will announce in the EventRunner thread when it's time to switch...
    There is also a new plugin for ZBS to support TQAE and future features...
    In the TQAE post I have changed all links to the new repository, but I would recommend to pull the repository with a GitHub client (that way it's easy to update too) - or take down the TQAE.tar.gz archive
    Could you also make COH, so it will update from Github like EV4 :-) its a mess to upgrade because too many EV4 rules depends on the HUE device ID :-). And i found a few bugs in COH, and know it will take me hours to update ;-) when reinstalling COH
    There are technical tasks: in one room there is the warm floor , which is included in the collector, on the collector there are servodrives which we can close or open. A typical scheme in general.
    The room has a thermostat that is controlled by air temperature, it turns on / off our servodrives.
    Also in this room there is a thermostat that is controlled by the floor temperature, and it must also turn on or off our servodrive.
    The main requirement: that the floor was warm, that it did not overheat and was comfortable in the air.
    The option I see: for the AIR thermostat to control the native FIBARO climate panel( futher AIR CLIMAT PANEL). And here for the thermostat on a floor - to make management from ER4 that it was possible to control system as a whole dynamically.
    For example:
    1) Our AIR now has 20 degrees, and we need 22 degrees
    2) at the same time the FLOOR has 17 degrees, and we need comfortable from 22 to 28
    3)The AIR thermostat will turn on and will heat up to our SET 22, but at the same time we CANNOT overheat the floor more than 28
    4)When the air heats up to 22, the floor needs to be maintained in the range of 22-28 (from practice - somewhere 1.5-2 degrees more than the desired air temperature) ... that's where we need the ER4 to control the AIR CLIMAT PANEL.
    Question: how to change the climate panel from ER4?
    For example:
    There are already support for dealing with individual thermostats (setting setPoints etc).
    If you want to deal with the climate panel directly it could be possible. The question is only what model to use when interacting with it.
    It's all divided  up in "climate zones" and you can modify the properties of them, including the weekday schedules.
    It's easy to add the code but I'm afraid it will be complex to use.
    could you for example like with ER4?
    1) read through the API the current set temperature, say from the climate zone with ID 3
    2) let's say the set temperature in the zone of ID 3 is now 20, and we want to change through the API it to 23?
    Thanks!
    Thanks!
    Yes, but it's a temperature for morning/day/evening/night and for each day.
    If you discover that now , tuesday morning, its too high, do you change it for just tuesday morning, or for other subsequent time periods too? (it may be just a few minutes before the next time slot so changing the current may not make a difference)
    for example:
    we have only 1 zone in the climate panel and only 1 temperature in the 1 zone for all day (all 4 Setpoints have the same temperature), and all days have the same temperature, but we turn to Monday, zone ID 1, Setpoint 1
    Edited by fastvd
    Guest kallecux
    Control of light scenarios
    Hello!
    I would like to control my lighting scenarios with ER4. To do this, I can, for example, switch on certain lamps in the morning at 6:20 a.m. and switch them off again at 8:00 a.m. Everything OK
    rule ("@06:20 => 66: value = 0; 66:on; 66:dim = {00:01:00, 'up', 00:00:01, 'Linear', 0.99}")
    But now I would like to start this rule manually (at a different time) via the YUBI app. To do this, I would have to trigger the rule "from outside". How can I do this with ER4? Or is there a smarter way to go about it?
    Greetings
    Karl Heinz
  • There are 2 ways to do  it.
    1. Add a button to the  ER4 QA.
    If  we add a button with id 'Test' and onReleased 'FEventRunner4' it will send the event (thee QA id  was 3101)
    {"type":"UI","value":[3101],"event":"onReleased","id":3101,"name":"Test"}
    This means we can do rules like
    This means we can either press the Test button or wait for 06:20 and we carry out the "morning routine".
    2. Create a  separate QA with
    and bind the function to a button. This will post the #morning event to the ER4 QA when the button is pressed.
    and keep the 2 last rules in the ER4
    On 11/1/2021 at 7:50 PM, fastvd said:
    for example:
