  • Well, you can put the safe true/false status directly
    If you use :breached When2turnLightOff will be true when it breached... etc.
    You can also make it a text string
    I need to read the status of the door sensor so i can use it for testing - In my case i uses a tri-state, "0, Breached & Not Breached." i use 0 to select to use one or the other rule (red arrows) to close the light. My issue i my PIR sensor dont cover the shower cabinet
    Edited by ChristianSogaard
    P
    [SOLVED] - BUT
    What is tAB=false, i found it in an example at
    Is there a way to test if the door sensor has been closed after the PiR sensor and use is in a EV4 condition ?
    P
  • On 12/28/2020 at 8:14 AM, jgab said:
    The tricky part is the last rule that needs to have a test that is false when the second rule's test is true.
    I have no idea what tAB is, 18 month ago and those brain cells are dead and replaced by now.
    For a sensor (door or motion) you can get the seconds since they last changed state.
    if
      Badevarelset.motion:last - Badevarelset.door:last > 0
    the motion changed state after the door. Of course you need to add tests if it's breached or safe you want.
    if
    I tested this rule
    it triggers just when door :safe and the condition seems to be ignored or something else so I tried adding logs
    and motion no matter the direction of entering or leaving the room is always the highest number -
    eg. Motion 18 + door 0
    So why is that ? - and why is the numbers 1-2 digits - i would expect the whole time here ?
  • 42 minutes ago, ChristianSogaard said:
    I tested this rule
    It's seconds since last changed, not the time when changed.
    How do I add a value to a variable, including the existing value of the variable ?
    Like this lastBreached=lastBreached+236:last; ?
    EDIT..
    Incoming sourceTrigger:{"type":"device","value":1655739749,"id":236,"old":1655737682,"property":"lastBreached"}
    is there a EV4 Rule syntax for using lastBreached=236:old or lastBreached=236:value?
    P
  • Please login or register to see this code.
    works, but also
    No, 236:last is actually translated to a
    So, it's always the latest value.
    Just now, jgab said:
    works, but also
    You could make your own rule to trigger on lastBreached
    and handle it the way you need...
    4 minutes ago, jgab said:
    works, but also
    Thank you :-) you are amazing ?
    Jan, good morning somewhere out of the blue
    Yesterday HC3 restarted a few times due to electrical problems in the house.
    This QA is't tuched for days.
    For sure it will be Fibaro acting up but failsafe is the goal.
    Any magic you can do?
    //Sjakie
  • I blame the HC3 :-)
    Well, it did restart.
    However, it's a bit old - it's v0.80 now.
    Jan, I thought I use the latest and greatest version.
    I only can downgrade??
    If I click >>QA it does't show other QA's
    /monthly_2022_06/image.png.6baaa6a9d386cd664bd80b21cf1099fe.png" />
  • Could it be the problem with the latest FW that has issues with updating labels/button in the UI?
    Jan perhaps you are right.
    Reverted back to 5.110.15 clicking buttuns respond better but still does't see the newer versions
    /monthly_2022_06/image.png.019e7ca8181f325a042255d4104ab498.png" />
    Jan, if I click downgrade he is upgrading fix 79 but no fix 80 and I cant see what version I have
    /monthly_2022_06/image.png.e75ad0963a05c0419b624586c349c200.png" />
    I only get 1301 and 1309 in between he skip
    Edited by Sjakie
    data
    Jan Iin QAUpdater when I select Event Runner I see only one QA updated 0.5 fix 80
    1302,1303,1304,1305 are not listed in QAUpdater but in tab Event Runner >>>0.5 fix 80
    Reinstalled QAUpdater did't solve
    //Sjakie
    //Sjakie
    If you have an old ER (0.5fix ...) that was created before QAUpdater, the QAUpdater can't see that this is an EventRunner QA. Later ER's have a series number inside that allow me to identify them.
    If you  rename your ER QA with something with "Runner" in the name it will recognise it as a v0.5 ER.
    Ex. call it "EventRunner X"
    then QAUpdater should be able to find it.
    ...and then you can rename them back to their old name.
    Jan,
    If I arm partition 21 I will get a proper log
    If I disarm in Yubii I cant get a log
    I tryed 21:alarm==false, 21:disarm
    Please advice,
    //Sjakie
