  • 21:armed==false => ...
    or
    21:disarmed => ...
    Jan,
    This goes wrong and I don't know why?
    Why I get value false?
    Used value   'Aan' or 'Uit'
    Plaese advice,
    //Sjakie
  • I don't understand your log.
    You say the rule is
    but your log output says
    so they must clearly be from another rule, as the log starts with "Aangemaakt..."
    Sorry in the meantime I modified all logs, GV gemaakt replaced bij Aangemaakt
    Problem is the $Sec_Beveiligen = 'false' I checked all QA's and nowhere is used $Sec_Beveiligen = 'false'
    Jan, this afternoon HC3 restarted by itself.
    //Sjakie
  • New version 0.81 with a new experimental feature - user action events.
    When someone interacts with a device in the app there are events emitted with the device and userid.
    Ex. a com.fibaro.multilevelSwitch device with id 756.
    When the user with id 917 turn on, off and changes dimming we get the events
    Which means that we can create a rule like
    rule("#user{id=917,value='action',data={id=756,actionName='turnOn'}} => log('Ann turned on the light')")
    Beware that the normal event
    is also emitted.
    Also the order of the events seems to not be predictable. I've seen the #device event being fired after the #user event.
    Anyway, will experiment more with it to see how it can be used.
  • Some more observations.
    The #user event is always sent, even if the device already has the state (as opposed to how the #device event behaves)
    Trying on the HC3 it seems like the #user event always comes before the #device event - however can't guarantee it.
    HI Jgab
    doesn't work in version 0.81
    The rules shown below
    rule("@{00:00,catch} => $WeekDay = weekdays[os.date('*t').wday];  log('Set GV into %s',$WeekDay)")
      Util.defTriggerVar("Lbathcounter",0)
      rule([[Livingbath_door:safe & @@00:00:10 =>    Lbathcounter=Lbathcounter+1; log('Light turned on %s times',Lbathcounter)]])
      rule([[Livingbath_door:breached & @@00:00:10 & Lbathcounter >= 1 => Lbathcounter=Lbathcounter-2; log('Light turned on %s times',Lbathcounter) ]])
      rule([[Lbathcounter < 1 => post(#livingBathventOff)  ]])
      rule([[Lbathcounter >= 1 => post(#livingBathventOn)  ]])
      rule("trueFor(00:10,Livingbath_sensor:safe & Livingbath_door:value) & !inlivingBathroom =>  Lbathcounter=0")
      rule("#livingBathventOn =>||Livingvent:isOff >>  wait(00:00:05); Livingvent:on; log('LivingBathroom is Vent On!')")
      rule("#livingBathventOff =>||Livingvent:isOn >>  wait(00:00:05); Livingvent:off; log('LivingBathroom is Vent Off!')")
  • Ok, what doesn't work more specifically?
    Did it work in 0.80? or what version did it work in? Nothing have changed in the last versions that effects the rules you have.
    Just looking at the rules I'm not sure I understand the logic with the counter, but you may be doing something clever above my head ;-)
    work in 0.79 version
    rule("@{00:00,catch} => $WeekDay = weekdays[os.date('*t').wday];  log('Set GV into %s',$WeekDay)")  => Catch not working
    rule([[@@00:00:10 & Livingbath_door:safe =>    Lbathcounter=Lbathcounter+1; log('Light turned on %s times',Lbathcounter)]])
    rule([[@@00:00:10 & Livingbath_door:breached & Lbathcounter >= 1 => Lbathcounter=Lbathcounter-2; log('Light turned on %s times',Lbathcounter) ]])
    when the door is closed
    Count is incremented by +1
    when the door is open
    Count decreases by -2
    If the count is less than 1, the light is off.
    Lights up when count is greater than or equal to 1
  • Your catch rule works fine for me (0.81), and I can't see any code has been touched since 0.79 that could affect this.
    Can you try to add
    _debugFlags.dailys=true
    and see if you get a message, "Rescheduling daily ..." ?
    And secondly, try
    rule("@{00:01,catch} =>
    just to see if there is a problem with exactly midnight...
    I assume you are running on HC3 and not HC3 Lite? ER4 doesn't run (correctly) on HC3 lite due to the 32bit ints.
    Jan, regret to inform you in Updater I don't have 0.81.
    0.8 is the highest.
    Strange if others have 0.81
    Version 5.110.15
    //Sjakie
    Edited by Sjakie
    add data
    0.8 is the highest.
    Version 5.110.15
    //Sjakie
    You need to click the refresh button.
    It should say
    ok sorry.
    Version 0.81 error
    Don't have it in 0.80
    //Sjakie
    Edited by Sjakie
    add data
  • 43 minutes ago, Sjakie said:
    ok sorry.
    Version 0.81 error
    //Sjakie
    Yep, that was a real bug.
    Fixed in v0.82 that I just uploaded.
    Jan error solved!
    But a new one occured
    //Sjakie
  • 7 hours ago, Sjakie said:
    Jan error solved!
    //Sjakie
    I think that you are running an old version (not v0.82). It's the same error on the same line as the previous error you reported.
    You are right.
    Updater skip sometimes a QA wierd all my QA's start with ER in the name.
    //Sjakie
    Edited by Sjakie
    its working
