  • I have update ER4 (v0.83) and QAUpdater (v0.66). They can both be updated with QAUpdater.
    The new things is that ER4 can query the updater QA and ask if there are any updates and if so, ask QAUpdater to update it.
    It is implemented using the old functions in ER4 so something like this should work (again)
    A new field is the .descr that contains the update string I provide with the release.
    The new things is that ER4 can query the updater QA and ask if there are any updates and n that case ask QAUpdater to update it.
    This is a nice feature - thank you for providing this.?
    I have minor feature request for the QAUpdater.
    When having updated a QA, eg. a Event runner 4, the QAUpdater resets all its GUI settings, so if you want to update eg 10 EV4, its a lot of clicking ;-)
    Would it be possible for the QAUpdater so stay in the same GUI settings, so i just can click once for my next Event runner 4, and then pres update ?
  • Yes, it should be possible I guess - added to my todo list.
    You have 10 EV4?
    What you could do is only have the rule in one of them and then let it update the others
    You need to have the ID of the QAUpdater.
    If you patch the EventRunner file at around line ~656 you can add the UpdaterQA ID to the event sent
    and you can do
    It will be in the next version of ER4 but I'm waiting a bit to release that....
  • A general question - how many ER4 QAs are you running?
    The reason I ask is that if you have more than 3 and think there are more efficient ways to do things - and probably not all rules need <1s response time.
    So what probably takes most cpu power in ER4 is the polling of events. I try to do it as efficient as possible and I never run rules unnecessarily unless events actually can trigger them - but anyway.
    An approach would be to have one ER4 to be the "master" and send events to other ER4 instance. The drawback would be that these ER4s would react a little bit slower (probably ~1s) but they would consume very little cpu when there are no events.
    My thinking is to implement it as an option in ER4 to poll for events itself or getting events from a "master" ER4
    Then you can have an ER4 with low latency rules (doing its own polling)  and other QAs that don't mind a bit higher latency and receiving events from the master QA.
    My reason for having more EV4 is structure - by rooms or functions.
    What Could work for me as well is having more files where i can build the structure and just having one EV4
    LIke -
    rules_Bathroom
    rules_Marius
    rules_eg
    /monthly_2022_07/2022-07-14_09-45-04.png.d149fcb1371190064d0f49662779b897.png" />
    Edited by ChristianSogaard
    P
    That's a good idea. You can do it already today.
    Create new file(s) and in each file add the content
    The in your main file inside main() you do
    you are a true mastermind ?
    Some Questions
    Should filename and module name be identical (identified with red arrow) ?
    i am getting
    [14.07.2022] [10:21:01] [ERROR] [QUICKAPP1640]: QuickApp crashed
    [14.07.2022] [10:21:01] [ERROR] [QUICKAPP1640]: main.lua:40: attempt to index a nil value (global 'self')
    rules look like this
    P
  • No they don't need to have the same name.
    But it's important that you have the loop that loads the modules inside
    in your main file as it needs the variable self.
    You could have your QuickApp:main() only to setup hometables etc and then have all the rules in the modules - or have some main rules (like updater) in the  QuickApp:main()
  • Ah!, Please halt the exercise!!! I just realised that this will not play so well with the QAUpdater that will remove your extra files.
    I will need to build in support in ER4/QAUpdater to allow for this - will have a look at it.
    LOL - I was just going to write that to you ? i found out already
    But now the rules are being imported ?
    ...and now I pushed v0.67 of QAUpdater.
    It will leave files untouched that's starts with u_...
    Ex.
    u_Bathroom
    "u" stands for user...
    Hi Jan
    I tried setup hometables in main file
    But it seems that these rules from my u_ColorProcessor file are missing the data from HTab
    i have a Scene that creates the HT
    and the Global Variable is updated
  • Yes, you need to put the loop that loads the rules after you define the HT table, otherwise it's not available when they are defined.
    Actually, maybe it's better to put the loop at the end of QuickApp:main() so your main rules load before the modules' rules.
    On 7/9/2022 at 9:25 AM, jgab said:
    New version 0.81 with a new experimental feature - user action events.
    When someone interacts with a device in the app there are events emitted with the device and userid.
    Ex. a com.fibaro.multilevelSwitch device with id 756.
    When the user with id 917 turn on, off and changes dimming we get the events
    Which means that we can create a rule like
    rule("#user{id=917,value='action',data={id=756,actionName='turnOn'}} => log('Ann turned on the light')")
    Beware that the normal event
    is also emitted.
    Also the order of the events seems to not be predictable. I've seen the #device event being fired after the #user event.
    Anyway, will experiment more with it to see how it can be used.
     Ohh this hade been nice too get to work :)
    HI @jgab
    i found instruction how to use button from another QA to activate rules in ER4 in attached post
    and got this error, will you help me to solve the problem ? thnx:
    [14.07.2022] [22:15:02] [DEBUG] [QUICKAPP22]: onAction:  {"args":[{"type":"morning"}],"deviceId":22,"actionName":"RECIEVE_EVENT"}
    [14.07.2022] [22:15:02] [DEBUG] [QUICKAPP22]: ./include/fibaroExtra.lua:2079: attempt to index a nil value (field 'ev')
    [14.07.2022] [22:15:02] [ERROR] [QUICKAPP22]: QuickApp crashed
    [14.07.2022] [22:15:02] [ERROR] [QUICKAPP22]: Unknown error occurred: handleJsonRpc
  • You need to put the event inside an event.
    I will update the post.
    43 minuty temu, jgab napisał:
    thnx @jgab
    i'm refering to this ,sorry guys, something goes wrong with the attached link :
    Edited by domin12
  • Ok, this is how it works these days.
    You create UI elements but set their onReleased to 'FEventRunner4'
    Whenever you press a button it will fire a ER event of type (ex. with ID='myButton'). ID is the QA ID, name is the UI element ID.
    So your rule becomes
    rule("#UI{name='myButton'} => ...")
    If you have a slider you do
    rule("#UI{name='mySlider',value={'$value'}} => log('Values is:',value)")
