Google Home / Assistant different languages
ryvaenge
Hi, will the fibaro app just be in english? Norwegian is coming "soon" to Google Assistant, Home later this year.
I use Alexa today, there is no other way to control with Google like the way Alexa does it by pulling devices to it`s own "smart home control"?
  • I started using it on my phone on english, so I got the answer myself on the second question. Fibaro devices are pulled out to the "Home control" section of Google assistant, can give nickname, so I can keep my setup in norwegian in fibaro, and rename them to english in google assistant.
    As you said, you can give it a nickname and call it up in english. That works fine for me with HC2 and Fibaro Home. Have you found any way to call up the devices in Norwegian?
