Roland declerck 0
I will replace some TL light in my garage with 2 PROLIGHT LED batten - 14W - (coupled) (non-dimmable).
The current light is connected to the Fibaro FGS223.
In the manual there is the following warning:
When connecting the Switch 2 act in accordance with the following rules:
• Do not connect loads greater than those recommended!
• Do not connect types of loads other than resistive and incandescent!
If i understand this correctly i can not use the FGS223 and i should replace it by a dimmer althought i do not want to dim at all?
Or can i still use the fgs223 as the load is quite small (2x14w) and the risk on damage is basically non existing?
9 answers to this question
