Linking to Fibaro fails "Something went wrong. Try again"
Frans
Hello.
Trying to link google home app on iOS with Fibaro HCL but get the same message every time. After adding Fibaro in Google Home I get "Accunts now linked". Press done and after 10 sek or so I get "Something went wrong. Try again".
Anyone with same issue who found a fix?
16 answers to this question
I have the same message or "could not update the setting, check your connection"
I checked all HC2, phone, google home mini are connected without any problem with fast internet. But problem still exist. Maybe this is problem between Google and Fibaro servers ?
I received answer from Fibaro Support. They know about this problem but they haven't solution for it yet. Problem occurs for big z-wave network (I asked what is big z-wave network, my with 40 physical devices and around 200 logical ;-( and I wait for answer;-)  ) or with HC connected to internet by ADSL with upload less that 5Mb/s and ping time > 30ms.  The problem is time out for devices status query. Support informed me that they work wit google and apple (same problem for messenger) for resolve problem but ... any date
Thnx drboss. My z-wave network with about 70 physical devices might also be too big. I'm pretty disappointed. Bought the Google Home just for being able to voice control my Fibaro. Hopefully a solution will come shortly...
It is a pity that Fibaro does not inform about it. Fibaro just announced that HC works with Google Home, even stars and fine text at the bottom of the page ...that this does not apply to all networks. I also bought Google Home to issue voice commands for HC.
Today I use OpenHub temporarily on my NAS for use Google Home wit HC (as interconnect).
I have the same problem, but only 3 z-wave devices off a HC mini - any idea if this is a different issue or the same one?
I'm in New Zealand so depending on where the servers are it could be a latency issue? (200Mbps internet connection so speed is no worry).
I just solved the problem. Mine was related to my Fibaro ID. When logging in with it on the Fibaro website I noticed my HC2 wasn’t connected anymore.
I removed the HC and then added it again. First without success. Then I looked at the access settings on my HC for the different users. It was a mess! Don’t know why but all of a sudden lots of permissions were unassigned. So I changed that, checked my Fibaro ID again, at that time it was connected to my HC, tried to connect Google Assistent again and it worked!
i have the same problem, but what is happening is that every time i try to link fibaro to google assistant, i get 2 security warning emails, like below
for different IP addresses every time, these IP's are from Amazon (www.amazomaws.com)
Suspicious Login Attempts Prevented
We noticed 5 failed login attempts to your HC2-036917 that seemed suspicious.
For your security, the following IP address: 34.243.52.82 has been locked for 30 minutes.
©2018. FIBAR GROUP. All rights reserved
Although the google/Fibaro connection works for me every now and then I get the same Suspicious Login Attempts email. I choose to ignore them.
i assume it stopped working after there was a patch (4.140) on 28th June 2018 for a security leak found, you probably setup your google assistant before that time, now it's no longer working, i do find it strange that Google uses Amazon services though
It has been working fine for a long time. Yesterday suddenly Fibaro did not respond anymore. Resynchronisation devices on GH told me it was not possible to talk to Fibaro. Cleared connection, but whatever I tried, I can not get it back....
GH support keeps telling me to clear out the connection and then to add it again... I guess they don't have clue what they are doing...
It worked for me as well. Thanks a lot ;-)
I removed my old and offline HCL, then I was able to link to my new HC3.
Hi All
I just got the problem again. Suddenly i could not sync the Fibaro HC3 with new devices. I remove the link between google and Fibaro. and tried to setup the connection agaon. Could not connect. I delete my Google home, removed all data. Tried to delete the HC3 from Fibaro Clould ID and reconnected it again. Without any luck. I also tried to Create a new fibaro account also no luck.
Hope someone find a solution.
Anyone know if its works hidding devices in Fibaro or does google home include those aswell.
I think its correct it to many devices connected to Fibaro that causes the issue. to slow to link all devices ( I dont think is an issues when its connected. I had 147 devices before i unlinked the fibaro from Google.
