amatt
Can someone help me with Node-Red?
I need to tell node-Red to change a global value in HC2.
Thanks for the Help
13 answers to this question
node-red-contrib-fibaro-hc2
0.0.75
but this version still in development. no ETA. sorry
but you can use simple flow
do not forget chage HC Ip address + set basic auth
Guest kallecux
Hi there!
Do you have newer information to modify a global variable via node red?
Greetings!
Karl Heinz
todo plan
1) fix reconenction on network errors
2) set global vars
when? maybe ath this weekend.
yes
oops: UPD no
only changed values :(
topic has name home/globalVariables
Edited by 10der
hoi 10der
i am totally new with node-red but wanted to try your "simple" flow
i have set my ip and credentials like this
http://user:password@ipHC2/api/globalVariables/{{{topic}}}
where put i my global like for example the global in HC2 = marantz into this flow
is it also possible to put the payload directly into the global of HC2 for example if i say to google or alexa or siri set input marantz to hdmi2
@Kage sorry, not sure what I right understand you
1st what url is? My not not required any http
2nd yes my node can’t change global var
3d you can’t change global var if user is not admin
so, if you want to change global  var please simple create a new VD with button where you can. Change global var and call press this button from NodeRed
thx for quick replay,
This is what i wanted to do,
say to Alexa "set volume to 40
i have a global named marantzVol
and the payload is, when i say the line, 40
now when the payload is 40 that is what i wand into my global to HC2 ?
When i youse your flow as above you mention change ip and basic auth.
so i did like
do i have to change de topic in this line or where do i put my global from HC2 in
I get the variable to change only it is the value that is given as Ololo.
now only if it can be the payload of ALexa
Edited by Kage
progress
For what purposes you are trying to use HC?
node red has a native tons ready for use solution for Alexa/ sonos etc
its look like tripping from Ukraine Lviv to Poland Kraków (~300km) via for  example Los Angles
When i say the frase "Alexa set reciever at 40" than the global in HC2 have to change in 40, That triggers a scene that controls the Marantz.
For now i get it to work only for text not numbers
i change the text value Ololo into a msg whit value payload
than when i say a frease like "On" it change the global in HC to ON
but whit numbers only it will not work.......Yet
HC2 (and not HC3) can hook parameters when you calling scenes
why you use global s for it?!
just encode your parameters  to table and pass to call as last parameter
in scene you can hook this parameters
no global var at all
i know it can be done by parameters directly into a scene but i am new with node-red and this is stap one ?
its not only for the Marantz but this is de testcase for me now
so for completing the first stap, how can i change the number from Alexa into a text-value, 8 must be "8"
GOT IT!!?
made a function with
var x = msg.payload;
if (x>0) {
 var msg_o = {payload : String(msg.payload)}
thx again
just playing with it, just raining outside
Edited by Kage
So global isn't a option because there is nog trigger if you work with startSource.
Then trigger it to startScene like 10der says. ☹️?
