Fibaro dimmer 2 always starts at lowest light setting
arcile
I have a problem that every time I turn off the light (Fibaro Dimmer 2) and turn it on again, it will go on the lowest light setting.
So for example:
1. I turn on the light, and it's a like 1%
2. Adjust the light to 100%
3. Turn off the light
4. Turn on the ligght again, and it's 1% (lowest setting)
Any idea why this is?
Best Regards,
Daniel
3 answers to this question
  • @akatar That sounds awesome, do you know what the setting is called? Tried to look through the software settings but didnt understand which one to use.
