Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
gotlandix
Two hc2 and Google home only for one house
So I have two houses with a hc2 in both. I also have a set of Google home minis in both houses.
However I'm only able to use voice to control one of the houses and the devices from the other house is not visible in the Google home app.
I can add the devices from the other house by talking to fibaro and after listing devices choose the hc2 from the other house, but of course then the devices from the other house disappear from the Google home app...
I don't know if this is for Google to fix or if Fibaro can list all devices for both hc2's.
Any suggestions on how to fix this problem is appreciated.
Share this post
Link to post
5 answers to this question
I have a similar question.
Got a HC lite in the beachhouse and a HC2 in pur home.
When I sync devices in GH devices from both houses show up in the first GH house.
Please guide me to the smartest way to handle two houses in GH.
Share this post
Link to post
We’ve solved a similar problem (using alexa not gh) by setting up a ha bridge in each of the houses, which point to the respective HC2.
We’ve then set up Alexa using different accounts in the houses so that only the local devices are linked.
Like that we can control the devices in the beach house when we’re there and the devices in the main house when we’re there.
Hope this helps.
K
Share this post
Link to post
Got the exact same problem, my HC Lite shows all devices in Google Home, not the HC2 i also have in our home.
Share this post
Link to post
  • Having two accounts doesn't seem to be the right way to go as @
     is proposing. I understand that it does work but it should be "out of the box" to have this kind of functionality I think...
    Share this post
    Link to post
    Ok for those interested, for now I fixed this by doing:
    - Go to
     , click remote access
    - Remove the HC that you do not want to be included with Google (for now)
    - Unlink (if already linked) your Fibaro account from Google Home devices,
    - Add Fibaro again, login and only the HC that is in id.cloud.fibaro will now show up on Google Home
    - After this you can re-add your second, third HC back to id.cloud.fibaro
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
