How to call a simple HTTPS command
I am trying to get this to work... I have a Fibaro Movement Sensor in the hallway and want to do the following..
When the sensor is breached, it should send out a https message to macrodroid link which will in turn turn the brightness of the Android Tablet sitting next to the door to 100% and then set the CCTV app to full screen. I am using Macrodroid to automate the part of the android bit and it all works. I just can't work out how to call the https link.
The link is like this. Any ideas how I can call it??  It can be either a scene or VD.
Many thanks in advance.. ( I have done a search of the forum and the examples listed are just too complex for me to understand.. hence I am asking here.) ;-)
Edited by rajp
5 answers to this question
On French forum you have good example for https with HC2
For unblock download you need create account and post welcome post in section "Nouveau ? Présentez-vous"
Edited by drboss
Hello @rajp
I have done a similar thing in that I make https requests to a service on the internet using lua code
Below is a link to my code repository, on the line indicated you will see a http request call being made. You will need to ensure checkcertificate is false as the fibaro system cannot verify ssl (https) requests.
Additonally, this code only works within a scene, not inside a virtual device. This should still work for you as I expect you will create a scene which is triggered by the PIR being ‘breached’
I hope that helps you to get going
Ian
    Thank you both.. I have the following code that does work now.. I could not get the syntax of getting the function defned properly.. but your code was very helpful... this is still quite raw, I will refne it further and then implement it....
    %% properties
    %% globals
    baseUrl = "https://trigger.macrodroid.com"
    local timeout = 10
    local http = net.HTTPClient({timeout=2000})
    function sendRequest(url)
    fibaro:debug("GOne into Send Req")
    fibaro:debug("BaseUrl is " .. baseUrl .. url)
        http:request(baseUrl .. url,
            options = {
                timeout = 5000,
                checkCertificate = false
    fibaro:debug("GOne out of Send Req")
    function run()
    fibaro:debug("Gone into Run FUnction")
    sendRequest("/**************")
    run()
    fibaro:debug("Running")
    Hi @rajp
    Have you got any documentation or link about macrodroid. I don't use it yet but it seems very powerfull with https from hc2 .
    3 hours ago, pepite said:
    Hi @rajp
    The only documentation was what is on their site... pretty powerful and useful too.. I just downloaded it and got it to run fairly quickly..
