Sign in to follow this
marcinsz
Heat Controller problem with temperature resuming
Hi Fibaro. I am using the Heat Controler with Homekit automation for some time now. No major problems with exception to frequent calibrations (which you need to address by the way).
My issue is that whenever the Controller starts its cycle of descaling or calibration or whatever it is doing (engine works loudly for a couple of seconds), it doesn’t resume the temperature setting it had before. It sets itself to 20 degrees Celsious. I have to set the temperature back to its previous setup manually from automation again.
My mode is set to manual and hold. The temparature is set by automation. My hub is atv4k.
Could you please help with this?
Edited by marcinsz
Share this post
Link to post
  • Really. Nobody?
    Noticed one more thing. Calibration disables holiday mode and turns on schedule. This shouldn’t work like this?
    Share this post
    Link to post
    Hi. I had the same problem in two heads. Please reset the head and it will work properly. For me after the reset they work properly.
    Share this post
    Link to post
  • I have reset today. I will share if this was successful :-)
    18.12.2018 update
    It still doesn't hold settings...
    Edited by marcinsz
    Share this post
    Link to post
  • I have contacted Fibaro. They say my issues are common and addressed in the upcoming update. Eta early Jan’19
    Share this post
    Link to post
