Matt_M 0
I have a FGS212 EU v2.2. I have set up a test rig of a mains lead and bulb holder before installing it in the wall switch. The following connections:
N - Mains Neutral and Light Neutral
L - Mains Live and Bridge wire
IN - Bridge wire from L
Q - Live to Light
I set the HC2 into learning mode and press the B button on the dimmer 3 times but nothing is being detected. I have tried doing a reset holding down B button for 3 seconds but that made no difference. Have I got anything wrong with the wiring please or are there any ideas as to what might be going wrong?
Thank you
9 answers to this question
