FGR-223 With ZStick Zen and DOmoticz
Funmsa
Dear all,
  I just receive my new FGR-223 and after mount them I discover different problems :
  Problem 1) My ZStick Zen (from Aeotec) discover the device, ok nice. But with label like "FIBARO System Unknown: type=0303, id=1000" but not with all paramters only these (I try to re-add device and also reset it completly)
150. Parameter #150:
156. Parameter #156:
157. Parameter #157:
3001. Protection:
  Perhaps with parameter 151 but normally must be setuped to 1 (roller blind) and not 4 AND ... I could't see parameters 151.... snif only 150 or 156 !
  Problem 2) I mount device with 2 toggle switch Up on S1 and Down on S2 but device only work like "gate motor".... I don't want that I want Switch Up => Up and Switch Down => Down... how to force to standard mounting ?
  Problem 3) Major problem on my DOmoticz state look state before last position... exemple curtain are in 10% and I send order to put it to 50%. My Domoticz receive command 50%, level is looking right and curtain go to position @ 50% nice. BUT less 1 after device resend position 10% and my domoticz and curtain look to be  in 10% position but in fact curtain is in 50% !
Please someone help me to solve these 3 problems
Edited by Funmsa
10 answers to this question
@Funmsa fgr-223 is roller shutter 3?
there is simply no support for the new module in domoticz, ask on domoticz forum to add new module.
(even with fibaro homecenter you have to use last beta for shutter 3 support)
  • Dear Akatar, thank you for pour answerand yes it s the new fgr-223 version 3.
    But can you please help me to understand that the problem come from Domoticz of recognize device and not ZStick or other ? Because device is discovered ans work fine....why juste dôme parameters aren t showed ?
    For me device parameters don t have to be depend of a data base of knowledgment from the box. Why it s not a simple list of stuff with value or enum into a JSON without any knowledge from domoticz....
    Anyway someone know the list of device supporter by domoticz and how to upgrade it ?
    @Funmsa
    zwave devices has command classes
    and some settings special for this module, as you can see the module is unkown type, but the basic command classes wil work. (not Always)
    settings specially for this module might or might not work.
    notes for the last homecenter beta:
    Version 4.521 Beta
    New improvements:
    • Added support for FIBARO Roller Shutter 3.
    Edited by akatar
  • I finally discover some informations about OpenZwave
    • List of known OpenZWave device :
    • Folder in Domoticz of xml device : domoticz/Config/[BRAND]/[device.xml]
    • Explaination :
    • Github of devices specification :
    So... Mr Akatar do you have (from 4.521 Beta) the fgr223.xml (like the fgr222.xml attached) but not documented on :
    Best regards
    No Mr Funmsa, i don't own a roller shutter.
    Edited by akatar
  • Dear Mr Akatar,
      Sorry if my question wasn't clear. I ask you if you have from Version 4.521 Beta of Fibaro box the file fgr222.xml with definition of all parameters.
    Best regard
  • Dear Mr Akatar,
      DOn't worry I could find another way based on the terrific work of Nechry thank you !!!
    Dear All,
    Just solve it ! I share with you how...
    Add file :
     => Special thank to Nechry !
    Modify manufacturer file to link to fgr223.xml :
    After just remove your device and add again and ... miracle all parameters are available !
    Beautifull
    Edited by Funmsa
    29 minutes ago, Funmsa said:
    Dear Mr Akatar,
      DOn't worry I could find another way based on the terrific work of Mr Auger thank you !!!
    Dear All,
    Add file :
     => Special thank to Mr Auger !
    Beautifull
    why should i worry?
    W dniu 26.12.2018 o 11:01, Funmsa napisał:
    Dear Mr Akatar,
    Dear All,
    Add file :
    Beautifull
    Using these files I still miss Parameter #41, therefore I can't use S2 to trigger scenes.
    I tried to add fgr-223 couple of times with the same effect.
    I want to use S1 to trigger one scene, which open all blinds and S2 to close all.
    I tried some trick:
    - record HTTP request which stores parameters to device
    - add missing param with BASE64 value (the same as for Parameter $40)
    - send API request to device
    - I recieve HTTP 200 OK response, however it doesn't change anything in device
    More details:
    When I go to Hardware-->Setup-->Node Management-->Control Panel
    I see this missing parameter but it's empty.
    In devices view it's missing entirely.
    Solution
    Fix fgr223.xml file and set proper type for parameter #41 which will be "byte".
    File from gitlab has improper type equal to list.
    Now remove all devices and add again.
    Regards
    Edited by majstermod
