Parameter 40 - How is this triggered?
Borgstrand
So in the setting under Parameter 40 I have it set to "3 - flash after receiving the alarm frame".
But how is this triggered?
I did assume that "General Alarm" would be the same as a motion or door sensor being triggered. But apparently not as nothing happens when I test to breach an armed sensor.
So how do I trigger this so that the switch start to "flash".
I assume that this "flashing" is done in the device itself and not through receiving on/off commends from the HC2? Using the "emergency light" in Fibaro Alarm quickly becomes useless if you want 3-4 (or more) devices to flash in case of a breached alarm as it overloads the HC2/ZWave network with on/off commands and the HC2 becomes slow in responses.
Excellent question!
Alarm Frames are not generated by your HC. Some devices can generate them. Note the specific wording: "Alarm Frames" - nothing to do with "alarms" on your HomeCenter (or other controller for that matter).
For example, Fibaro Universal Binary Sensor:
If you want the first input to send an alarm frame then you have to set P 5 to 0 (notice the word "generic):
Parameter No. 5
Type of transmitted control frame for association group 1, activated via input IN1. The parameter allows to specify the type of alarm frame or to force transmission of control commands (BASIC_SET) Default value: 255 – BASIC SET
Possible parameter settings:
0 – Frame ALARM GENERIC
1 – Frame ALARM SMOKE
And if you want all devices in direct reach to pick up that alarm frame set P 13 to 1 or 3:
Parameter No. 13
Transmitting the alarm or control frame in “broadcast” mode (i.e. to all devices within range), information sent in this mode is not repeated by the mesh network.
Default value: 0
0 – IN1 and IN2 Broadcast inactive
1 – IN1 broadcast mode active, Sensor 2 broadcast mode inactive
2 – IN1 broadcast mode inactive, Sensor 2 broadcast mode active 3 – INI and IN2 broadcast mode active
Does this help?
  • Excellent answer :-)
    And what devices are capable of sending these types of "alarm frames"?
    Only have Fibaro motion and door sensors that would be appropriate to use for this, and they don't seams to be able to do this?
