TSN
When a device suchs as a dimmer, switch or Fibaro eye needs to be replaced it gets a different device number.
so i have to change all the scene's where its in.
is'nt there a way to replace the device without change the device ID?
its quite a lot of work to change al scenes where its used in.
If this aint possible, it might be an idee of adding it to one of the next  firmware updates?
Like a button: Replace device >> delete old device>> then include the device >>> and it keeps the same Device ID, so no changes need to be made in all the scene's it is in.
Greetings TSN
3 answers to this question
@TSN
There is a way to create a hometable. If you Google Fibaro hometable you find a YouTube with a explanation. But also in the next treat you can find out hou to do.
Yes, there are workaround solutions.
The elegant solution is that one what @TSN write.
The working one is the hometable...
Greetings TSN
+1
