TSN 2
When a device suchs as a dimmer, switch or Fibaro eye needs to be replaced it gets a different device number.
so i have to change all the scene's where its in.
is'nt there a way to replace the device without change the device ID?
its quite a lot of work to change al scenes where its used in.
If this aint possible, it might be an idee of adding it to one of the next firmware updates?
Like a button: Replace device >> delete old device>> then include the device >>> and it keeps the same Device ID, so no changes need to be made in all the scene's it is in.
Greetings TSN
3 answers to this question
